485hp 24psi?
figgie
Twin Cities, Minnesot-ah
Nope. Not on the stock 7m head you won't. The 7m head affect the turbo efficency zone by a significant amount and also affect the VE of the engine. Keep in mind that the more displacement the less intake manifold pressure needed to get to the same power.
What are you comparing the numbers against? A 2jz or even worse, a S54?
supra88gr
110
s dub
my motor is stock except a mhg(7m) i just got the car back and that is what it says on the dyno graph. 24psi 485whp 478wtq maybe the boost gauge is installed wrong?
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
That's really not that bad of numbers.
I'm sure you're just frustrated to still see a 4 in front of your other 2 digits...;)
But as mentioned, That's about right.
Care to post your dyno sheet? How large is your turbine on that 35R?
Jeff
I would have expected more also, but I didn't realize the stock 7m head was that restrictive.
Is the 1jz head just as restrictive stock vs. stock? My 1jz made 543rwhp @ 24psi, but the head had a mild port and polish, but it was on stock valves. I was later told by someone on here that a port and polish was useless with stock valves........apparently they were wrong. I cant' remember who told me though.
gtimportfanatic
Mk3 Addict
May 21, 2008
277
Hartford CT
manny those are some pretty good numbers.. i say just do some head work and u in there.. i dunno if i told you.. bbut i spun a bearing on my supra and i think im just going to go 1J and call it a day for next summer.. but i still want that Emanage if u got it
Are you crying?
There's no crying in Supras.
You take your low horsepower and BHG's like a man damnittttt!!!!!!!!
