4.10 torsen help.....PLZ!
Bock
CNDBOOST
Jun 7, 2008
60
Ottawa
i have a 92 jza70 , i recently took it to the track (Had an awesome time) , On the drive home I started to notice a slight clicking coming form the rear ( like big rocks in the tread) ? since then it has progressed slightly.... it now make a Tin like grind when i turn low speed lefts? visually noting i can see , I think possibly the wheel bearing or axle or diff ? If someone might be able to steer me in the right direction or any advice , that would be GREAT!
tissimo
Stock is boring :(
Melbourne, FL
I assume you have a japan imported car? The stock jza70 came with the torsen rear end and it is pretty weak. You've probably broken it. Find a MA70 rear end and swap it in (gearing will be different if you dont swap Ring and Pinion).
gaboonviper85
3,236
Northeast Philly
Wheel bearings will make a rumble sound while driving and will change pitch when turning and shifting weight....it will also cause the center wheel hub to get hot...
Bock
CNDBOOST
Jun 7, 2008
60
Ottawa
Thanks a lot for the input guys , gonna tackle it in the A.M, ill let you know what i discover.
Any one know the gearing for the MA70 rear end? or a link for this swap? ( i am still searching...)
Thanks again
Bock
CNDBOOST
Jun 7, 2008
60
Ottawa
Info found ! ( for above post ) thanks
but i have a new symptom , maybe a little more helpful.
Today on the way home from work , i could clearly hear a humming coming from the rear, now its a very mild hum ... but its not a recognized supra noise ;( It only occurs during load , while coasting in neutral it goes away?? carrier bearing? LSD? fluid flush?
any more input would be greatly appreciated !
Thanks Bock
Cz.
CAR > FAMILY
Seattle, WA
It could just be the hum of the rear end. You could try adjusting backlash of the r&p to see if maybe it's too tight or too loose.
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
It's probably your diff that is broken, the JDM ones like yours are notoriously weak. I had the same diff in my car and when it broke, I could still drive it, only I was getting a strange vibration, and the side seals were leaking lots of oil because metal shavings were chewing them up. When I looked inside, the diff carrier was sheared completely off the ring gear, but was jammed so tightly against it that the car would still drive.
Hard to see in the pics, but look closely, you'll see the sheared case where it joins to the main gear.
[/IMG]
Bock
CNDBOOST
Jun 7, 2008
60
Ottawa
Right on guys ! thanks for the new info and opions! i feel alot beter to at least have narrowed it down , too bad my wallet doesn't feel ant better lol :3d_frown:
thanks again BOCK
p.s Tekdeus yur car is pure sex!!!!! :boobs:
