3pc wing?
mikes_88_supra
158
Missouri
I need to no how to mount the side pieces for the wing. There are 2 little studs and 2 screws. But how do the little studs hold the side down is there a clip for them or do they just keep it from sliding around. and is there some kind of seal or caulk that keeps the water out of the inside of the wing.
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
Idk what exactly you are trying to say but there are two plastic clips that you insert into the body of the car, then you can screw the wing to those clips. There is supposed to be a seal around it but it's probabally worn off or rotted away.
mikes_88_supra
158
Missouri
there are the 2 clips with the screws on them and there are 2 little spike things but i dont no what they are for.
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
mikes_88_supra;1348610 said:
where can i find these clips for these because thats what i was talking about
OOoh okay those black rubbery things. Thats probabally a dealer only part. Maybe put a WTB up for them and get some used?
mikes_88_supra
158
Missouri
i just bought some little clips that push over the top to hold it on there. i think the will work and ill just use some rtv gasket sealer to make it water tight.
