Does anybody have an unmodified stock 2JZGTE block that they could measure the piston deck height on? It should only take you a couple of minutes if you have the head off....
does it have stock pistons in it and has the deck been machined?
All I need is for you to put a straightedge across the middle of 3&4 or 2&5 with the pistons at TDC and use a feeler gauge to determine how high they come up out of the bore or stay below the top.
