Guys/Gals,
I noticed that folks who dropped a 2JZGE or other engines in their MKIIIs just throw away TEMS and go to coilovers. While picking IJ's brain on various subjects, he mentioned that there is a Camry TB that sends out L1, L2 and L3 signals. I got curious and started to dig around.
I dug around and came across the following document:
Using the above, I found the pinout of the 2JZGE TPS and made the following spreadsheed:
Next is my dilemma. The Cressida TB:
vs the 2JZGE TPS:
Now, if the Cressida TB has the same diameter as the 2JZGE TB at the TB butterfly, I was thinking of a TB butterfly assy swap along with TPS should do but chances are, the dimensions will differ from shaft size, shaft length... you get the idea.
Next, I thought about going to a machine shop to have them adapt the Cressida TPS to the 2JZGE TB but I'm not sure how true the TPS calibration will be, assuming that the camry TPS needs to be calibrated.
Again, can anyone please shed some light on the above or alternate method? The rest of the wiring is fairly straightfoward and it's just a matter of time to put it together.
Pardon the essay as it's a summary of my research.
I hope this thread will be fruitful enough to be stickied.
vs the 2JZGE TPS:
