2JZGE-T temperature control issues
veedubin
Official SM Decals
3p141592654;1848261 said:
You are calculating the difference between two temperatures, not the actual value.
Let me give you a simple example, if there is no temperature difference measured, i.e. 0C, then what value would you expect it to be in Fahrenheit? Use you calculator and see what you get, then ask yourself if it makes sense.
I see your logic, and it now makes sense. Thanks!
Basically if my car runs at 87*c at idle and 93*c at highway cruising, I'm seeing a delta (change) of 6*c. Wich is only 10*f not 42*f
Again, Thank you.
te72
Classifieds Moderator
6,623
9
WHYoming
veedubin;1848182 said:
The MKIII undertray is like the unicorn... Everyone's heard of it, but no one has ever seen it... :biglaugh:
I have one... bought it new at Toyota for $90-110. Good investment. ;)
That said, make the use of the air going into your car more efficient before you start worrying about the fan situation, IF your fan is already in good shape, leave it be. Like I said (might have been in another thread), your temps are normal for a JZ.
