2jzge question
SupraMadness
27
Del Rio
Ok so i recently bought a 2jzge and i wanted to kno the correct compression ratio. Ive read tht its 10.5:1 more or less and ive also read tht its 9.1:1 more or less. Im goin to go NA-T and im going with a 1.3mm hg. Any help would be great. Thanks
If you use gte pistons then just use a tt headgasket. HAve to make sure the pistons are the right size for the bore tho.
OR just use a 2mm hg and tune good.
SupraMadness
27
Del Rio
Yea thts the route im going, im just gona go with a 2mm hg and the good tune. already have a megasquirt tht im using for my setup. Thanks
RacerXJ220
Interdimensional
Abalama
Just use a stock 1JZ or 2JGTE head gasket and keep the GE pistons.
A 2mm head gasket lowers the compression into the lower 8's. Any GTE head gasket brings it to 9:1 or so.
