Ok so i recently bought a 2jzge and i wanted to kno the correct compression ratio. Ive read tht its 10.5:1 more or less and ive also read tht its 9.1:1 more or less. Im goin to go NA-T and im going with a 1.3mm hg. Any help would be great. Thanks
hvyman;1724499 said:Its 10.5:1. Id get a 2mm hg to drop it down some. Somewhere around 9:1 would be better.
hvyman;1724561 said:If you use gte pistons then just use a tt headgasket. HAve to make sure the pistons are the right size for the bore tho.
OR just use a 2mm hg and tune good.
