2jz swap... and tranny questions
mk3ftMFw
Mini Toon Burnout!! FTW!!
Jan 24, 2007
95
Cincy
ive done some research but some of the articles/threads kind of contradict each other and ive become confused. :1zhelp:
I know that the 2j can be swapped somewhat easily. I know i need a 2j cross member, and the 2j mount correct? Educate me... :nono:
Also the 7m auto tranny is a teensy bit different then the 2j auto tranny.. so can i keep the auto tranny until i get some money to pick up an r154?
I don't know much about the transmissions, but I know for the 1jz, you have to change the bellhousing from the 1jz to your transmission. I already had a five speed, so I just used the tranny that came with my clip. Good luck
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
you can either swap a late 89+ crossmember and mounts, or you can use BIC motor mount adaptors. to keep the tranny (dont quote me) but i think you can use a 1j auto tranny from a supra.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
JZ block bolt patterns are diffrent from 7M
so what ever trany bolts to a 7M will only work for 7M
and what ever works for any JZ engine will work on any other JZ engine
In order to use the R154 or the W58 5 speed manuels you need the JZ bell housing
I hope that clears it up for you.
the 7M autos will not work because they are one piece But any JZ auto will work on any JZ block 1 or 2
Dont try to use the 6speed the rear diff is way off for the 6 speed gearing
If you want an auto the aristro autos are easy to find and cheap i bought most of my a340E autos for $60-120.
crazysupra2JZ
740
Georgia
i'm doing the same thing right now.
here's what i got.
1JZ/2JZ motor mounts from BIC $180
1JZ bellhousing from champion toyota $300
1JZ lighweight flywheel from 935motorsports $235
7M/1JZ clutch kit from 935motorsports $450
tsuper92
supra addict
Apr 7, 2005
1,376
mass
the 7m auto trans bellhousing does come off and can be swapped for the jz auto bell
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
mrsuprafreak said:
You will also need:
1993-1998 2jzge Flywheel
7m clutch set
im pretty sure you would need a 1JZ flywheel if you intended to use a r154. Ive never heard of using a 2JZ-GE flywheel
mk3ftMFw
Jan 24, 2007
95
Cincy
so here it is..
2jzgte (the cheapest part, SYKE)
2jzge flywheel
1J auto tranny bell housing
BIC convert mounts
2J EC and harness
and all the single turbo conversion crapola.. what else, im trying to get a shopping list together.
crazysupra2JZ
740
Georgia
also the throttle cable.
if you get the aristo 2jz then yo need to spend about $550 converting the oil pan to a rear sump.
if you don;t want to use the hydro fan then you need to get the mechanical fan waterpump. i paid $150 for mine from toyota.
you'll also need to get the pulley for it.
you'll aslo need arp flywheel bolts. got'em from driftmotion.
kabanimk3supra
kabanimk3supra
Apr 11, 2007
511
oklahoma
hey guys, im doin the same 2jzgte as well
so far i have
motor(big single turbo)
bell housing and r154 tranny.
im not sure if i have the right crossmember, the car is an 89. it has the square mounts, so i think im gonna need the IMC brackets someone correct me if im wrong. and my other question is, would i use a 7mgte clutch with a 2jz flywheel? any other (good) suggestions?:1zhelp:
mrsuprafreak
Where does it end?
Aug 14, 2005
267
Orlando
so far i have
Use 7m clutch
1jz or 2jzge flywheel
1jz Bellhousing
Mounts change crossmember or buy brackets
You might want to use the search for more info!
