im just starting my 2jz swap, so i have a few noob questions.
is the injector resistor required to run usdm injectors?
should i be run a stock usdm crank pulley or one of the driftmotion replacement ones? i know they say the underdrive pulleys are a big no no
are electric fans better than running the ls400 fan clutch + 7m fan blade?
how much boost can you run on stock jdm twins? i keep hearing that they are weak and can not handle more than 12psi
do i need a map sensor for the aristo or is that programmed in the aristo ecu?
sorry if they seem like retard questions, but this jz stuff is somewhat in confusing and im still trying to figure it out
