2jz NO! NO! They'v gone bad
carter;1447417 said:
this is Kyle Hunter's car... he might be on here... but for the modds and money that he had in this... I could have tracked down and killed whoever showed this.
Lets put it like this, i'm not the biggest fan of this kid,
2jz w/ 6speed trans and v160 swap
GT35R
EMS with favored injectors & tuned
in an NA body
but in the defense, he did manage to get it into 12.3 last time i heard...
Those mods equal 12k?? If so i'll stay 7m or maybe converted to 1jz
V160 is expensive as hell...
kotu100
1,899
Easton, Ma
my srt-4 is faster than half the cars on here, with about 3k in mods.
they're the supra equivalent of the FF class.
The only things wrong with SRT-4's is:
- Usually owned by dumb kids that run around with open downpipes (or around here a 4" side dump)
- It's FWD
- It's still a neon
Outside of that, it's cheap, fast, reliable (for how cheap it is), and is useful in actually carrying people and things LOL.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
Let's get something straight.
Just because you spend money doesn't make your car fast.
You buy all the goodies, for a 7m, 2jz or 1jz. If you suck at driving it will be slow, if you are a shit mechanic or take it to a shitty shop it will still be slow.
I mean I'm running 14 PSI on my mk4 right now with the 67mm out of my mk3 and it's making about 420 WHP and maxing out the 440's. It's trapped 90 in the 1/8th and most likely will do 115 down the 1/4. However, with a shitty launch I'll still be in the high 13's.
That mk3 was slow as shit because that srt4 doesn't look fast at all.
Srt4's are fast I'll give credit where it's deserved, anyone that says they aren't is on another planet.... There aren't many 4 bangers that virtually go 12's with factory mods....
Yes it may just be a neon, the same goes true for the supra....
It's a car, if you love it and enjoy it, it really doesn't matter what kind of car it is.
lowtaco
282
Under a damn Toyota
SRT/4 guys also hate the "its a Neon" comment too. Gotta a buddy that talks shit all the time about his and how theres not a MKIII that could touch it cause he has the 60-1 Haun turbo kit, because all our cars are too heavy and only make 230 stock. Gives me more of a reason to mod the hell outta mine and put a Neon owner in his place.
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
88-7MGTE;1447434 said:
comment left by the neon owner
December 17, 2007
"no, the maker of this video is an idiot, he thought i had a stg 2 wg on my car. but no, my car is 99% stock. stock ecu, stock wg."
LMAO!!!!!!
wtf is up with these stages? people say that and it makes me laugh so hard my guts hurt.
"had to get stage 3 motor mounts cause the b16 is so pumped"
Keep in mind I've been utterly destroyed by an SRT-4, so I have a LOT of respect for them.
Did a 60 punch and he left me like I threw an anchor out the back of my car...
Ninja edit: SRT-4's actually have stage kits from Mopar.
queenskid926
Tires yeling @ every Lite
Jul 27, 2007
1,112
New York City
also if he really has the 6spd in the gear, the gear ratios are too short for him to really do anything. Even with the 373's he needs something lower like the mkiv 3.2 rear end ratio. All he is doing is going from redline to redline every gear change pretty much and not using the car's powerband. That supra shouldve walked all ova that srt4, hell i raced one with my stock 7m stock turbo and pulled away. Freakin skittles lol
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
upgradedsupra;1447250 said:
You have proof to back that statement? What are the mods etc..on the 2J car.
Mods are listed in the video. My proof is everywhere on the forum of stock to near stock cars. Obviously there are several exceptions such as yourself but in general I would say a mk3 with a 2j and a gt35r is decently quick for this forum.
carter
"The Ninja"
Nov 1, 2005
743
Ohio
I could see that, but i still blow away at throwing 12k at the car and then have to take your motor out once it gets back from the shop and rebuild it. Hell i figured a full 2jz swap was right around 7k w/ trans (tops)...
But either way, sometime earlier this year or last, he hit in the 12s
And a buddy of mine here has an srt4 @ 22psi and that thing is pretty quick, breaking traction in 3rd is pretty cool to me even if its a "neon"
Dec 3, 2003
6,653
Canada
Well, mine, I understand, the big percentage is more of what I was referring to is all. I don't think it is that high.
It is FWD, it isn't hard to break traction at 250FWH ;) A friend of mine had a Neon (srt-4) he sold it, he was tired of always fixing it. (It ran mid 12's.)
Duane
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
GT35R
in an NA body
Did he change the rear end too? What's wrong with putting it into an N/A body? All an N/A body is is a body that doesn't have a wing and a turbo badge. Hell, my Supra is an N/A body and it doesn't make a difference other than the fact that I don't get hassled nearly as much by the cops or ricers (especially ricers) who like to pick on Supra's because they have a wing and a turbo badge.
What do you mean by favored injectors? And how is breaking traction and going nowhere cool? My buddy gave me a test drive in his 313 FWHP Eclipse Spyder and spun the tires doing 40 MPH (with decent tires) and went absolutely nowhere. Seems very pointless to me. Atleast with a RWD car if you spin the tires at speed you'll accellerate (and hopefully not crash) since you're transfering weight to the driven wheels and not off them (as is the case in FWD cars).
IndyMK3
I Hate Godzilla Too!!!!
May 15, 2008
323
Indianapolis, Indiana
ok ok.... so just last week i talked to kyle hunter ( the owner of this car) about this video (not even knowing it was posted up here lol) and anyway... when this video was taken was the day he got the engine put in the car... the first time ever driving it... so driver mod it is... well technically learning car mod lol.... and before this sad video was taken he asked the guy who does all the LIMA RACING videos to not put it on the internet because he was sure he was gona get beat.....
***edit**** oh and sadly this supra WAS beautiful.... someone was texting in their mini van and rear ended kyle ... insurance said it would cost like 6k to fix... =( but i think he is getting out of the supra game for a while and selling everything... he posted pics up of the accident on Ohiosupras.net
but yes that srt-4 WAS fast.... hint hint (was lol) he PO took all the aftermarket parts off and sold it.... then 2 weeks later BOOM.... one of the rods said F**k this Im out....
Supra_Villan
needs his car done
Nov 10, 2007
662
Wellsville MO
Poodles;1447216 said:
What's with the comment on the SRT-4's having "bad trannies?" They run getrags...
Outside of that, they didn't say what boost they were running or anything like that...
THEY ARE GARBAGE.
this i promise you they don't take much upgrading very well at all. My friend had an 11 second srt4 on a 50trim with an afc and some other mods and he was on his 2nd tranny and sold it right before a 3rd was needed. Look around getrag or not they are shitty trannys.
suprafanatic
1,607
Greenwood, IN
haha.. sorry but SRT-4s are not fast.. They have to be pretty heavily modded from what i'v seen. I'v never lost to an SRT-4 and i'v raced several that were modded. Hell i raced a modded SRT-4 that was on like 22psi, full exhaust and a bunch of other stuff, i smoked it and that was back when i Just had an upgraded CT turbo on. One night when i was driving my supra through Indy there was a group of SRT-4 guys that come up beside me. One of the guys in the SRT-4 was yelling at me calling my Supra an Old slow piece of SH*t and i just laughed .. Well to bad for him the light in front of us turned red, So he had to back up his mouth now. Light turns green and i was gone. I wait a while and let him catch back up and we went from a roll.. same out come. I pulled on him like he was going in reverse. Only thing i like about SRT-4s is the aggressive front end.. other than that its still a neon and FWD.
Supra_Villan;1447859 said:
THEY ARE GARBAGE.
The vast majority of MKIII's can't pull 11's without breaking...
Now that they've gone to the trucklet SRT-4, it doesn't hold as true, but name another car for the price that performs as good with a warranty and factory support for power mods...
