Well I fixed the cut out issue I was having before turned out to be the tps plug well i was messing with it one day and one of the tps wires must of touched another one and it sparked pretty good. When I went to start the car had no check engine light and car just turned over and wouldn't start so I checked my fuses under the dash and they were all good. So I'm wondering is there any other fuse I should check? I checked some under the hood and they were good also but there is a couple you can't really tell if they are bad. But I'm starting to think it might of shorted my stock ecu out. I just placed a order on a ecumaster emu but I want to see if I have problems in fuses or ecu.
