I just installed a Walbro 255 and did the fp relay bypass and the check engine light came on and wasn't on before. Anyone have this happen?
			Poodles;1703941 said:Check codes...
7mgangsta;1704134 said:Yea, I put a fuelab AFPR in and put in a fuel feed damper bypass in too so the J tube is no longed in use. But My car is still running lean as hell lol I'm about to just junk it after 3k in upgrades lol I'm going to pull the intake manifolds off, turbo manifold off and pull the head off to check the head and install new MHG with new manifold gaskets. I tested it positive for combustion fumes in the coolant with an HKS MHG... How do I check engine codes on the 89 7mgte oh ps I'm running a safc 2 and it's almost maxed out, 550's lex afm intercooler and hardpiping. Thanks.
Nosechunks;1704463 said:How is it lean as hell with 550's and lex afm? Unless you mean maxed out pulling fuel with the Safc. Leads to my next question of how do you know its lean? Do you have a wideband? If you know its lean then that would likely be the issue, Though usually lexafm and 550's run rich.
