20 psi
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
Can I ask why you're boring the motor .040 over and not .020? If this is the first rebuild on this motor I dont see why you wouldnt just stick with .020 over.
lppro
LP Performance & off road
Apr 21, 2007
895
Sugar Hill, Georgia, United States
i probubley will end up just doing a 20 over.. and i do plan on an ugraded turbo (when i get some more money saved) and for fuel i plan on 680 injecters and a Walbro pump.. and a lexus afm.. the fuel system and afm will probubley be the next mod after i get the motor back in and brocken in.. do you guys know what kind of power the stock 5 speed will hold?
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Plenty if you drive it right.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Just think about it....You can have all the shit in the world on your car, but if you are using the stock turbo that isn't effecient over 14psi, what's the point? Go get the CT26 upgrade then ask.
whenmunkysfly
scratch that...going 2jz
Jun 26, 2006
746
United States
and a fuel controler too can't just run 680 injectors with a lex afm it only works with the 550's unless you get a controller.
lppro
Apr 21, 2007
895
like i said i am upgradeing the turbo... just not right now.. maby in a cupple pay checks (=
lppro
Apr 21, 2007
895
what do you mean by controler? i have a hks fuel cut defencer... i dont know much about it though it was in the car when i got it..
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
On drjonez' website, he claims "the skys the limit" with the R154, and that may be a bit sarcastic, but lots of supra owners are putting down numbers in the 6 and 700 range with R154. And with the mods you are mentioning, I dont think you should have anything to worry about, given that your tranny is in good condition to start.
kracin
Sleeper
Apr 1, 2007
68
aiea hawaii
oh no... lol whatever you do, please look up the things that have been done to your car. that fuel cut defencer depending on how it was done may destroy your engine if you try to crank up the boost and dont know what your doing.
secondly using 680cc injectors with no piggyback or standalone is going to run pig rich no matter how much boost you throw at it, i was running with about 10% taken out at every level and 15% at a couple trying to get it to run lean enough with 550's and an upgraded ct26 *only 12/1* youd be lucky to be able to tune it out trying to add in extra unmetered air somehow.
running 550's and a lexus afm and an upgraded ct26 57 or 60 trim and a walbro fuel pump with afpr is your best bet to get the numbers you are looking for, but you have to remember that those arent the only variables in the formula, the stock intercooler if you still have it is going to restrict, not only that but if you still have the stock turbo elbow its a big restriction no matter how big the exhaust system is on your car
running the 550, lex afm, 60-1 10 degree exhaust side clip ct26, my car dynod over 400, but youll be hard pressed to get it to run more than 320-340 at the wheels without tuning capability. especially with 680's in there.
just read some faqs, go look at 7mpower.com to see what people run on their setups to make bigger power, and definately dont just crank up the boost without some way to tune it out, the worst possible thing is to crank it up to 20 psi, think your in the sweet spot and have a spike that ends up causing permanant damage to your rebuild.
Dunckel
2,949
Spokane, WA
don't listen to these guys. turn your fuel cut defender to ch.3 and turn up the boost as far as it will go. and don't forget to to put a nitrous sticker on your window. good for aerodynamics and a hp gain of 5.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
IJ. said:
1mm/0.40" overbore will maybe make 1>2 hp difference (not enough to measure accurately on a dyno)
The CT is the bottle neck and won't let the motor make any more hp no matter how big it is.
Listen to Bishop he's actually done it.
Ian is right. Read this and comprehend, especially on the overbores, compare the differences between them: http://www.supramania.com/forums/showthread.php?t=44148
Also, throw away that damn fuel cut defencer before you blow your shit up... I didn't realized there was another page when I posted... I hate it when I do that :3d_frown:
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
Tony Ortiz put down 822rwhp and ran a 10.2 with a stock R154 transmission.
He's now pushing quite a bit more power (or getting there, anyways :icon_bigg )...so I'm unsure of what setup he's going with now to put it to the ground.
Also - For the original poster: You need to understand that tuning is everything. It's not as simple as having a big high compression V8, a bunch of modifications and throw it on a dyno crossing your fingers (it's never quite that easy, anyways); but a car with forced induction (let alone 20psi on a stock CT-26)........trust me, you'll be wanting to do some kind of tuning. :icon_wink
Jeff
lppro
Apr 21, 2007
895
Jeff
how much dose dyno tuning usuley cost?
