2 step or anti-lag
2 step is a type of anti lag. Usually for launch control.
IS your car stock?
2 step kills turbos quick.
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
i havent heard about 2step killing turbos (well little by little) not as much as anti-lag which is used in wrc and frequent changing of turbos
figgie
Twin Cities, Minnesot-ah
two step is an artificial lower RPM limit than the phyiscal hard rpm Limit. 2 step is usually acheived by cutting gasoline and not ignition. 2 steps are usually used in cars with auto transmission.
ALS system are highly configurable in when the ignition cut takes place the amount of fuel and add DBW and it also controls what % the TB stays open. Unlike a 2 step, ALS is controlling the combustion process to take place when the exhaust valve is open allowing the combustion energy to spin the turbo instead of pushing the pistons down.
They are not the same. They are only related in what they control.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
flash shift for me.... with bit of timing dump and increased fuel
only down side is i can not run per programed no2 map has to be manually pushed by a momentary switch
