1jz with PS but no A/C
NecroCyde
Lurk R
Calgary/Brooks, Alberta Canada
hey there people, ive searched everywhere and I can't get a straight answer, im wanting to ditch the A/C on my 1jz but keep the power steering, the problem is that the P/S pump bolts to the A/C compressor, removing the compressor doesnt really yield any hard points to bolt the PS pump to, do you have to disassemble the A/C unit to get the front plate off of it to have something to bolt too? this car is going to be for the track so i wanted to shed those unneeded lbs, any ideas people?
thanks
10secdream
Got Boost?
Sep 11, 2007
767
Edmonton, Alberta, Canada
thanks
I am curious about this as well because I would like to remove my AC but still maintain the power steering.
str8_6
master yuepeng
Mar 14, 2007
241
wa
i just installed p/s without a/c.
the pump is held on to by the upper bracket thats connected right under neath the intake manifold and then also a bolt holding the p/s pump bracket to the engine...THATS IT. nothing else.
also get a belt for a 2000 audi a4 2.8 liter. it works PERFECT.
NecroCyde
Lurk R
looks like that will work just fine, im shocked actually, im just going to put a nut and washer at the end of the bolt where it goes through the mounting point to make sure is stays the fuck put and i bolted the other point where it was holding strong, even though that bolt sticks out like 1.5 inches from the actualy mounting point on the bracket. should work, now i just need a belt and to rip out the condensor from the shell.
