1JZ with a Ct26!?!
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I finally stayed away from SM for a night after work and made what I was talking about doing for a while. This is the "beta version 1.0" done with only $20 in materials (and almost a full 2 lb roll of mig wire! :biglaugh:)
I know the flow will obviously be better with mandrel bends but this is just to basically mock it up and test it. I have a 120v mig welder so I do the best I can considering the tubing is .120" wall and the flanges are 3/8". None of the transitions are more then 45 deg and the tubing is 1.5" id so it should flow ok. The twin's inlets are only about 1.25" and they are oval shaped.
The turbo will sit within 1/2" of exactly where it would be in the 7m engine bay. I did that so it will accommodate all the 7m turbo and exhaust upgrades most people already have when they do their 1jz swap.
If the twins take a crap, you could buy an inexpensive ct26 and slap it on. Or, for under $500 you could have a CT26 upgraded and have a fast spooling reliable turbo capable of 400whp+, and not have to make a custom exhaust and not need an external wastegate.
If this works out well I will have it made by a "professional" in mandrel bent stainless and the pricing will be affordable.
<commence flaming> :biglaugh:
I now have a lot more respect for those little Chinese dudes making ebay manifolds!
simpsons7s
Its pronounced Nu-clear..
Oct 9, 2005
253
Riverside, Ca.
not bad ... with a bit of polishing and grinding that one could look really good. I like the idea .. I have another idea I will share when I see you.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Allan_MA70 said:
1jz conversions make soooo much sense!!!!!
That's enough from the peanut gallery!:biglaugh: You argumentative powers are weakened in my thread! :icon_razz
You're stranded on an island, you would just drive in circles anyways. :icon_razz
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Allan_MA70 said:
Im starting my own business soon! its main product is a loom that lets you run a 7m-gte with a 1jz-gte loom!
pshhhh, right. Where are the cam sensors going to be mounted? Sell shoes or vacuum cleaners instead. :biglaugh:
My 7m is already speed density :icon_razz They have a 1jz loom for the 7m already, it's called Maft Pro.
OneJoeZee
Retired Post Whore
aboard the Argama
::dead horse:: :icon_neut :asshole: :blah: :blah: :blah: :sleep: :joshers:
i think that about covers it
Allan_MA70 said:
did'nt the 1jz have turbos???
ohhh thats right they blow up all the time heheheehehehehhehe
Allan_MA70
1,055
Melbourne, Australia
fuck off fosters you yanks have no taste at all!!!
