1jz turbo upgrade
suprasonic
Pembroke Pines, Fl
Ok, I want to get a 1jz with a 2jz bottom end, but i'm having
second thoughts bacause i cannot find any turbo bolt-on upgrade.
Can some of you tell where i can get a good single turbo kit.
-thank you for your help
drunk_medic
7Ms are for Cressidas
Woodstock, GA
www.takakaira.com
HKS and Trust kits
http://www.suprastore.com/grt78tukit1j.html
1JZ Turbo kits at SupraStore
http://www.sfp.net/shopdisplayproducts.asp?id=182&cat=Toyota/Lexus
Turbo Manifold at the bottom for the 1JZ - pic is for a 4-cyl manifold, but they say that they make a 1JZ manifold.
I'd go with the last option - since with a 1.5JZ you will have the displacement to push turbochargers meant for a 2JZ, you can get one so long as it has the same flange welded on. You can make your own kit that way.. or you could buy a 2JZ turbo kit, use everything from the kit aside from the manifold, sell whatever manifold comes with it, and buy this one. Should adapt VERY easily, if not seamlessly.
