1jz swap no spark...
tercelica
98
Las Vegas
Hello, I finished putting in my 1j into my supra, but I can't get it to start. It turns over but doesn't start. I'm not getting any spark. A few guys on the forum is helping me out alot already(Thank you very much), but I still can't get it to fire up. I'm getting a Code 14 which is:
Ignition Signal
Diagnosis
* No "IGF" signal to ECU "A" times in succession.
A = 6-8 (7M-GE)
A= 3 (7M-GTE)
Trouble Area
* Igniter and ignition coil circuit
* ECU
I was told to check the IGF wire from my ignition to my ecu but I don't know which wire that is :(. Any help is much appreciated.
Gtstarga
89
Bristol. England
With a true JZA70 you should use the 2JZ engine codes. Not sure how this will convert on a 1J swap. Just a thought may be the same code diagnostic but worth looking into.
tercelica
98
Las Vegas
I'm for sure no spark. I checked the first three coil packs, and from there i figured the next three wont work either. so no IGf?
jetjock
creepy-ass cracka
9,439
IGf is generated from spark so no spark, no IGf. Forget about it and move upstream. I'm not that familiar with this engine so I can't offer too much but you'll need proper cam/crank sensor signals to generate ignition. Check for +12 power to one side of the coils too. Lathrop huh? My condolences ;)
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
Measure the 6 wires between the igniter and the ecu for conductivity, that's what "I was told to check the IGF wire from my ignition to my ecu but I don't know which wire that is" means.
Also check the plugs on the coilpacks, when they're a bit old they go brittle and break causing a bad or no connection.
Do check ALL cylinders for spark and let us know if they're all out or not.
