Okay so about 3 weeks ago i dropped a 1jz soarer in to my 87 supra originally auto converted to 5 speed got it all wired up started right up the 1st try. 1st try driving started breaking up at 3k-3500 rpms so far i been starting the car with a trigger switch i wasn't able to start the car with the original starter wire reason is because when the car is on it's getting constant power. engine light only comes on when the car is off and when the car is on it goes away and hooking up te1 to e1 no codes...
i got all the wiring info from here **How to wire a soarer 1JZ into MA70**
So far i done was swap a bunch a stuff and make sure every thing was grounded out correctly.
here a list of things i done. new crank sensor, swapped out throttle bodies, swapped out igniters, new map sensor. shrink wrapped my coils, checked for resistance. i can't remember what ill i done
i honestly think some thing hooked up backwards and is causing it to break up at 3k rpms and get constant power if some one can please help me to the right direction that would help me out so much
