1jz Fuel Pressure?
Tim
regular member
Oct 16, 2006
272
CA
I just got an adjustable fuel pressure regulator kit and I was wondering what the stock base fuel pressure is on a 1j with the vacuum line off??
bigaaron
4,692
Pomona, CA
www.driftmotion.com
We usually go with 38psi, but for your purposes Tim, you might want to go with around 45psi. That will let you lean it out a little more using your afc, which should increase the fuel cut boost pressure.
Tim
regular member
Oct 16, 2006
272
CA
cool thanks guys. That is with the vacuum line off right Aaron?
