I'm in the process of a 1jz swap and i noticed some surface rust on the flywheel and pressure plate.
I'm planning on buying an act HD PP and solid disk.
Now, should i resurface the original flywheel? or should i spend the extra on a light weight flywheel?
Also, where could i get my flywheel resurfaced? the local tuner shop said they could do it for $80-$100, and they were the ones to recommend the light flywheel.
I'm open to all options, any input would be greatly appreciated! thank you
