1jz auto on a 7m
You will need a 7m bell housing. Might as well build it if your going for any kind of power.
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
The 1j transmissions that I have in my garage does not have the spedometer out put on the output housing because it used and electronic sensor.
You need to count the splines on the input shafts and use the correct converter for the trans as well.
Only reason I can see to do this is if the Jz trans is known to be in good condition.
