1j is in but idle is rough
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
so finally got the swap done in my SC but idles is quite awful. i was gonna throw a timing light on it but i have the type that connects to a plug wire... so how the hell do i check timing on it lol. also is there any thing like a CPS i can adjust or do i just make sure the crank and cams are lined up. thanks
Freshmaker
396
Oconomowoc, Wi
You can't adjust timing like a distributer as far as I know. TPS can be adjusted, but only do it if your sure it needs adjusting. It is quite sensitive.
Do you have any engine codes? Checked your ECU caps? One other thing to check is make sure you mounted that thing that removes "noise" from the igniter circuit to a good ground. I have never dealt with a problem but heard it can cause some mis fires.
My 1jz had quite a bit of "pops" to it when I first started it up. After driving for about 30 seconds the idle cleared right up though.
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
hmm where is this noise filter? after looking at a few things i noticed that i can unplug all the coilpack plugs and nothing changes. except cylinder 1 and 3 i think its running on 2 cylinders... so the filter thing somewhat makes sense
Freshmaker
396
Oconomowoc, Wi
It has 2 wires going to a small black box. Its mounted on a small metal bracket. It should be around your igniter somewhere.
That doesnt really sound like your problem though. What was involved in your harness modification? Here is a diagram of the 1JZ. Checking the wires between the ignitor and the ECU is easy enough I would start there. Checking the ECU caps is easy too.
http://jzgte.com/tech/1jzgte/1JZ-GTE.Wiring.v1.1.pdf
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
well since i did mine with a soarer eng in a sc not a supra all i had t do was extend the body plugs everything else plugs in
Freshmaker
396
Oconomowoc, Wi
Have you checked your ECU yet?
If that is good, I would start with normal cylinder mis-fire diagnosis. Locate the missing cylinders. Check for spark, check the injectors and circuits.
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
checked ecu, its all good no messed up caps or anything. then I went to trouble shooting. all coils ohmed 1.2 and all are getting power. Timing is lined up. need a way to check the injectors tho. also take a look at this what do you guys make of it
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
yah lol thats why i was like wtf is going on. ive never seen it with the front half and back half like that tho. im not worried bout the richness honestly im worried about the back half.
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
ok little more narrowing down and im def not getting any fuel to the rear 3. does anyone know what would cause just the rear injectors to not put out fuel.
Freshmaker
396
Oconomowoc, Wi
Sorry, I was gone for the week-end. You made some good progress I see.
3 firing and 3 not firing, that seems pretty strange. To be more specific: Our injectors are batch fire. The ECU sends a signal that is supposed to fire 2 injectors at once. If the ECU was bad you would have problems with cylinder 1 and 4 for example.
Your problem seems to be after the ECU. So, check the wiring to each injector, and check the injectors themselves.
Freshmaker
396
Oconomowoc, Wi
Ok, lets check the signal wiring now. Since we know 3 injectors are getting signal, we can use them as a reference.
Your going to pull off one of the plugs to a missing cylinder, then the plug to the corresponding working cylinder.
Make sure your ignition is off to be safe.
Then, check continuity between the pins of the plugs. You should have pretty much no resistance.
The corresponding plugs are as follows:
1 & 4 W-L wire
3 & 5 W-R wire
2 & 6 W wire
Also check the resistance of each injector while its not plugged in.
This shows the wiring if your interested.
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
ok i think its fixed. one of the pins was not in all the way in my ecu plug. all seems to be well now. it still has a tiny bit of roughness due to idling really low but it revs very nice and clean. so i may adjsut the idle up a bit
91 mK3
Laaaaaaag
Aug 22, 2006
242
Hayward, Bay Area
maybe you might want to check and see if your tps is at where its supposed to be. that should help your idle. make sure your coilpacks are connected and nohing is broken. also, drive it around a little if you have fuel to all of your injectors. sometimes it hels.
