1j Fuel cut, cut
supraboymk3
99
Oakland Ca
Hey guys so I just got my 3" exhaust done last thursday:icon_bigg, witch is the last thing i needed to do as far as bolt on mods go. Now im hitting what i think is fuel cut around 14 psi (stock twins). I just wana make sure before i go buy a FCD that this will get rid of my problem & will i need a walbro pump to, or just FCD should be good enough? Running 1jz on stockers, FMIC, Intake, dumps, 3" downpipe, and now full exhaust, no boost control stock pump. Wasnt having issuse before @11psi, but then again i did have my stock exhaust on there lol. :aigo:
te72
Classifieds Moderator
6,611
7
WHYoming
Make sure your plugs are gapped correctly. I had a similar issue after replacing my y-pipe (oh how fun that was...), gapped the plugs to something like ~.28 or .028 (I forget exactly), and the problem went away. You shouldn't be hitting fuel cut until after 16psi on a 1j.
supraboymk3
99
Oakland Ca
Wow really, ok I always though fuel cut came around there but ok ill check them tomorrow. I did notice a hesitation the other night after getting off full boost. But it happen like a 30sec latter after I got off full boost. But ill check the gap thanx
supraboymk3
99
Oakland Ca
So I checked the gap on my plugs today and they were around .35 so I set them @ .29 and I still get a big stumble @ around 14, 15psi no check engine light gose on though. What should I do next, please help. Thanx all
f00g00
586
Kuwait
I added an FCD an AEM wideband and a manual boost control. Stock cut was around 14psi, after FCD Im running past that and with the wideband did a test run with the boost up to 20 and the stock injectors were putting out around 12 AFR so I have it running around 17 now. Gonna put some steel wheeled twins and 440's after I get a dyno run in then should be ok up to 20PSI.
supraboymk3
99
Oakland Ca
Ok thanks I'll start off with a FCD and get a wideband shortly after if it dosnt go away then buost control turn the boost down till I get it tuned. Thanx
supraboymk3
99
Oakland Ca
Hey yall I have a quick question, so i was thinking of trowing a high flow cat back in there for 2 reasons. Number one the smell, its to strong of an odar ever since i got the 3" catless exhaust done, i feel like ima pass out when im in traffic lol. Second reason would be that it would creat backpressure. right? not sure kinda dumb at this but i think it would drop my boost a lil witch is exactly what i need right now. So if i get a high flow would this reduce my boost a bit? 1 or 2psi less thats what i think i need to prevent my car from hitting cut.
open for suggestions
thanks yall
f00g00
586
Kuwait
Im not sure about the boost getting lower with a free flowing exhaust but if you are getting overcome by exhaust fumes then your liftback seal might need replacing. A small tear will allow fumes in.
supraboymk3
99
Oakland Ca
thanks man I just order one from DM
supraboymk3
99
Oakland Ca
f00g00;1698535 said:
you might want to verify the integrity of the seal
I will
thanks
---------- Post added at 07:21 PM ---------- Previous post was at 07:20 PM ----------
I will
thanks
---------- Post added at 07:28 PM ---------- Previous post was at 07:21 PM ----------
Ok so I have enough cash to get the FCD now but iv been doing research and a lot of people don't think its a good think to have a FCD. Now I'm just confused I mean is it going to hurt my engine even though Im not raising the boost on it at all? just trying to avoid Fuel cut on the stock boost right? Idk what do you guys think i should do
please help
mkiiichip
1,434
WI
I applaud you for coming to the conclusion that the FCD sucks and is dangerous.
If you want to raise the boost semi safely, you need slightly larger injectors, and a tuning device. Then you can turn up the boost whatever % larger the injectors are.
supraboymk3
99
Oakland Ca
yeah just wish i had the cash to do that
wynne240
15
greenville, nc
Im doing a 1jzgte swap in my s13 240sx. Im kinda lost too on what I should do because there are so many mixed reviews. I have a turbonetics 68 trim, 560cc Injectors, apexi neo and stock ecu. Am I able to tune it to run right with this setup? I've searched and one person makes a convincing story that I can and another person says that i can't. Thanks for the help
