1g gte
JStoked
646
Edmond, Oklahoma, United States
Looking at buying one of these motors for cheap. So my question is can they make any hp? I have done some research and I understand that they like to spin rod bearings and only put out 210 hp. So any info on to or not to buy this motor would be great. Thanks.
A big problem is that there isn't much for aftermarket support.
But with enough boost anything can make power.
F1 turbo engines will be like 1.6l making 600+ hp.
mjsn1
284
Qatif
My friend has it in his mk2, and from what i can see its a tough little engine with a great sound that you can beat up all day.
Remember some guy with a big single on one making 400HP+ in a first gen celica. Stock block IIRC.
Not a bad engine, but underpowered for the fat MKIII and hard to find parts for.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
As poofles said, hard to find parts for unless you're able to source them from Japan. Underpowered to make the MK3 move at all. Now in a lighter car... yeah it'd be great. I've wanted to squeeze one into an AE86 Corolla or a Mazda Miata or some super light car light that. It'd have a great power to weight ratio, with a small single like a GT30R or something like that on there it'd spool nicely and make great power, the only thing that'd have to happen is a battery relocation and lighten up the front end to keep weight balance around 50/50.
mattsplat72
is sofa king
Jan 17, 2006
1,738
[video=youtube;fwCG_eAgGTY]http://www.youtube.com/watch?v=fwCG_eAgGTY[/video]
Not to terrible. Consider the X90 most likely is an Auto. The supra didnt give up to much of a lead and appeared to keep the distance the same for the duration of the run.
That's probably the worst launch I've seen in my life...and it's even worse that BOTH of them did it. Maybe it's because both motors have no torque? :sarcasm:
Still, no idea on mods from that vid though.
SupraMedical68
Formerly medic91x
Feb 26, 2007
376
Nashville/Clarksville
Poodles;1924932 said:
Not that either. It's a good motor, but hard to find parts for and too small for our fat cars.
Parts and displacement aside would you say the motor is about the same the 7M-GTE in terms of reliability levels?
I wouldn't have a huge problem with that if the parts were more accessible.
Keep in mind I'm not trashing the 1G either, I don't have an opinion on it one way or another.
Tom_D
UK
This was my old 1G, I loved the car, I did look at other turbo options etc, but had always planned on a jz again just for the after market support, there's not too many in the uk, only a handful from what i've seen, however there's far more info on the australian forum for them if you wanted to stick with the 1g
[video=youtube;q4I2zHDpYnA]http://www.youtube.com/watch?v=q4I2zHDpYnA[/video]
supra1jz
284
Auburn, Georgia, United States
This is my AE86 with a 1ggte gt40 .70 ar low boost set at 11psi and made just around 300hp
supraguy@aol
Well-Known Member
Dec 30, 2005
4,245
47
Atlanta
http://img.tapatalk.com/d/13/11/16/utazusa6.jpg[/IMG[/QUOTE]
SEXY.
And the sound from a 1GGTE is awesome.
