1987 GE Auto To GTE Manual
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
Yeah we have all new vacuum hosing and running used vsvs....seriously we made 3 more tie wraps contraptions tonight, the clippy parts on the connectors looked like they were just PRIED off....but we're have alabama/texas rigging skills so we'll be fine:]
It would be a shame if it sat there any longer, we found another one in a junk yard just like it so we have our parts car...it's missing the hatch and the wheels:]
But hey if this joker runs i'll be surprised and happy:]
You don't happen to know the gear ratio of a NA rear end?
Oh and got the Intake manifold on getting it ready for flywheel(prolly going fidanza) unless you gotta good stock one laying around:]
timing belt, water pump, clutch and putting in the driveshaft
it'll be done soon, though darn Christmas and it getting exspensive
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
Got a new slave cylinder, timing belt, water pump, timing belt tensioner and spring. Getting pedals next and lines. More pics to come:]
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
Well, i finally got some new pics!!!
Here are some of the parts we've gotten in.
Radiator
Slave Cylinder
GMB Water pump
Crp Timing Belt
Clutch Master Cylinder
Clutch Kit
Brand New Toyota OEM Flywheel
Here's some car body shots. Getting ready for paint.
Got the clutch pedal in, hooked to master cylinder. And YES! We cut the brake pedal instead of replacing it. Took like 10 minutes. Yeah...a WHOLE lot easier than replacing the whole pedal.;]
Put Flywheel on
Here is the Intake/Throttle body we're gonna Use
HAHAH got Yah Good.;]
Got to looking at some connections for the Auto Tranny. There are 2 of them that looked like they were cut and crimped together.....Which i know it doesn't matter since we're going to manual. But i don't won't anything to throw a code or anything break because of it.....Plus, I thought reignmaker would like to know:]
Also, i've removed the auto tranny ecu. Do i have to hook it back up? Will it throw any codes?
Ok more to come. Gotta get some clutch plate bolts and we're in business.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Those cut wires are where they bypassed the neutral safety switch... Which in turn is why the car lunged forward and bumped my truck causing that little dent in the front, lol...
ViR2
Supraniac
May 20, 2006
932
Lithuania
www.hpaddict.eu
so they can do better work then. Removing stuff like lamps, or turn signals are easier then taping them, and the end result would be much better.
I don't want to be rude and under evaluate your work, but it just looks like you have to do it once again to get good results :)
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
Oh We know, it's only going to be a temporary paint, because good paint jobs around here cost money. We're building the car then worry about paint later when we eventually go turbo.
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
Yeah...But did it look like thats at a body shop? It's out rent-a-shed.LOL
More pics SOON, gotta get bolts to bolt pressure plate the flywheel. Can i get these at like advanced auto or should i get from dealer?
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
Allright!!! we got a pretty good start tonight...We've gotten everything we need so far so...
Here are some new pics, camera phone FTW....
New hoses(From dealer...:[)
Owner/Helper during this transition of pain in the ass...;]
Complete
It took a big dump on us during the middle of it...:[
Well it's going in the car next so we'll see what happens!
oh and our victory secret mascot dog ftw
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
Oh how i love dark pictures....Here is a better view.
Grinder
Ready, set, GRIND!
EXCELLENT
ok so here goes, colby(Owner of car, i'm just the camera guy/slave worker) Was torqueing the drive shaft when it slipped and he hit the ground at tramendous speeds....He broked his thumbs we think.:sarcasm: We tapped it up and kept working....:]
