1986 AE86 Corolla GT-S Supercharged
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
Well it's nearing completion of work at the body shop, I was a bit unhappy with the finish on the hood and trunk so they are going to sand and re-clear those panels as well as polish a few other places. I've got some black-out tape to go on the door b-pillars and they are going to undercoat the wheel wells all around and apply some sealer on the rear quarter to wheel housing seam, similar to how new cars are. I also got in some thicker clear 3M film to apply in front of the rear wheels, I'll draw up the patterns when I get the car back. Reassembly starts next week!
Jeff
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
So it's been a tad busy at the shop lately, so my car's been getting worked on a bit slowly, but it's almost ready to leave the body shop so I can start reassembly. The hood has been reclearcoated, the trunk was repainted and they've installed a bit of the glass and got the blackout tape on the door b-pillars. I think the quarter glass should be going in today or tomorrow, so I hope I can get it back on Friday or Saturday. Then I can start the long process of reassembly next week.
I've got new window mouldings coming in today and I've also ordered a bunch of other bits and pieces (clips, screws and cushions, etc.).
Looking forward to seeing more parts installed on the car, sorry about the dust!
Jeff
te72
Classifieds Moderator
6,625
9
WHYoming
Jeff, just dropping in to say hello. If I ever found myself in a position where I didn't need to work, and didn't need money (such as a lottery winning situation), I'd be doing exactly this sort of thing. Restoring and tastefully modifying random cars. Sell them off if I don't find myself completely attached to them, and make the world a better place. It's a shitty business plan, but frankly, most artistic ventures in the automotive world are.
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
In the spirit of keeping this thread active and awesome, here's a picture of the car from just before it snowed last year and ruined my fun:
More to come this spring!
Jeff
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
So, it's been a while, last year I ended up driving the car a bit, I had all of my TRD bushings installed front and rear, as well as my TRD 2-way LSD. Taking out the RH rear axle proved to be quite the challenge, even by AE86 rear axle standards. I ended up removing the axle housing from the car and having a couple of techs at work go at it for a few hours with a bigger slide hammer. Eventually it came out, but not without some collateral damage (more on that later):
After doing some driving with it, I also determined that the front-mount intercooler is way too much piping between the throttle body and the intake manifold. I feel the best way to fix this is an air/water intercooler setup. It keeps the piping short, and allows me to customize the water lines without having to cut any holes in the body, and also allowing me to run complete factory under covers. I have the core, water pump and water reservoir, just need to get a heat exchanger and have it all fabricated.
Even after replacing my brake master cylinder, all my hoses (with stainless braided), rebuilding all the calipers and replacing pads and rotors all around, I am still a bit unhappy with the braking performance, so I have ordered a set of Endless SS-Y front and rear brake pads. They haven't arrived yet, but I do have a new set of front and rear shims for them. I ordered in a set of Japan-spec shims, as they use a shim on the inner and outer pad as opposed to just the outer on the North-American cars.
Took it out early this year for its first drive, still a bit too much gravel on the road, but I was very careful. ;)
I also parked beside an Echo and enjoyed how much smaller (mainly shorter) my car was compared to the much newer "economy" car.
I also spent some time doing a 3-stage polish and wax on the paint. There were a few areas that had some hazing due to wetsanding dust nibs, and I wanted to take care of it. Just by hand, but it turned out extremely well, I think. The lighting wasn't the greatest when I took the pictures though.
There are a couple of remnants on the car from when I was young and poor, notably the outer tie rods which are aftermarket. Also when switching to the manual steering in the car, the new rack came with aftermarket inner tie rods and boots. Last time I was under the car I decided that was enough and ordered new inner and outers. I've also got a clunk in my steering when parked, though it has persisted through changing the rack, the inner and outer tie rods, the lower u-joint and the intermediate shaft, so I'm pretty sure it is either the upper joint or one of the bearings/thrust stoppers in the upper column. I will find it and fix it, but for now, new tie rods.
I spent the better part of the last six weeks trying to find all the vibrations I am feeling in the car, and found that my center support bearing was worn, as is the rear extension housing bushing on my T50 transmission. I replaced the support bearing and plan on replacing the bushing as well, though in the course of doing this inspection I also determined that not one, but both of my rear axle flanges are bent. I did hit a curb (though not hard) back in 2005 on the RH side, the same side that was a major pain to get out last year when installing the LSD. I also suspect some of my more "creative" attempts to get the axle out may have done more damage to it as well. Either way that doesn't explain the bent LH axle, but regardless, it was obvious I needed new axles.
So that's where it sits for now. I also have rear decals for the trunklid being produced to OEM standards, and may possibly sell them if there is any demand for OE-quality (actually OE qualtiy) reproduction decals.
Come see it at Driven 2015 on the 23rd in Calgary!
Jeff
SupraMario
I think it was the google
7
The Farm
Full year + without a sound...says it's been a while...lol
Man I have been looking for an AE86 for a while now, even a beat up one, such rare cars :/
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
Silver MK3;2048326 said:
Your attention to detail always amazes me. I'd love to see you do this to a MK3 one day.
Thanks. I'm not saying I'd never do a MK3, but it's of a similar vintage, and so getting things can be pretty hard (especially since people didn't seem to do the same sort of stuff with the cars so parts ended up getting discontinued longer ago). Finding stuff for the A70 can be even harder than for the 86 sometimes (and vice versa I suppose, but in general). Ideally if I was going to do something with a MK3, it would be in a bit nicer condition to start with.
Suprapowaz!(2);2048337 said:
Any vids coming soon so we can experience the joy of driving such a machine?
Never really thought about it, but that's a decent idea. Perhaps I'll take some video next week. :)
Another MkIII;2048374 said:
This is awesome! Pretty sure I saw this posted on Reddit a couple years ago.
Yeah, I should probably post some updates over there too, I've got so many places to keep things updated, haha!
Well it's been a while! I was quite surprised I hadn't posted any updates in that long, for some reason I stopped taking as many pictures... I'm going to try to make sure I keep taking just as many. They're super fun, even stock/slow, just a blast to drive. You should get one.
Jeff
SupraMario
7
The Farm
Jeff
Where would you suggest to look? I'm checking CL daily but they are so rare that there hasn't been one pop up in months.
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
That I don't know. :( Club4AG, perhaps Hachiroku.net (though that's more for PacNW). There's also AE86FC I suppose. I haven't actually tried to buy one in a long time, lol.
Jeff
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
So I've been cleaning up my front mudflaps this weekend, installed my windshield mouldings, and today my replica Euro-spec rear mudflaps arrived from Australia! They're quite decent quality, obviously I would much rather have OEM, but haven't been able to find the correct ones in good enough shape to make it worth buying them yet. I've been trying to get them for the better part of 8 years, haha. Still, I am quite happy with the quality of these flaps, I've yet to see how the fitment is, but once the new screws arrive I'll give them a go before the show this weekend.
Jeff
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
Finally got the hardware for the mudflaps in today (along with the weatherstrips for the windshield side mouldings). The rear mudflaps seem to fit quite well actually, I was impressed:
Also got the transmission bushing swapped out. Toyota does not sell the bushing separately for anything past mid-84, but the dimensions of the bushing remained the same with only some small differences. I would obviously have preferred the newer bushing, but it was worn so I'll take what I can get:
Got a correct label for my fuel lid to match my GZE swap and finally got my trunk decals as well, looking forward to getting them installed, probably tonight:
New rear axles, new rear bearings, new studs. I'm hoping that I no longer have wobbly wheels!
More to come!
Jeff
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
So I got the car back together, the new axles helped quite a bit with the vibration, as did the new transmission output bushing, though I do still have the vibration under load above 95km/h. Now that I have eliminated these other vibrations, I feel that once I get rid of the one under load the car will drive quite nicely. I am also experiencing some excessive LSD noise/chatter from the TRD 2-way that I never had last year, I've been running the same fluid the entire time and it was dead quiet last year but now it is quite noisy. I am going to try some other fluids/friction modifiers and see what I can get working. I hope that the LSD is okay.
The factory shifter is now back in the car, though it didn't have the boot on it and my original boot was torn, so I am going to need to get a new boot for that as we
Also of note was the Driven 2015 show here in Calgary this weekend. I spent a ton of time getting it ready as did Josh G. from Stampede Toyota and my buddy John and I brought home the award for best restoration, which was definitely a fantastic feeling to be recognized for what I've done with the car.
Jeff
Silver MK3
1,517
Madison, AL
Congrats on the award! For the boot if you don't go OEM Toyota I would highly recommend Redline leather goods. They're stuff is higher quality than the OEM stuff, and I can tell you only want the best for this car. That's what I've got in my Supra. The shift boot, ebrake boot, and armrest cover.
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
I have two OE boots for the car, one from an MA61 Supra and one original for the AE86. I just switched back to the AE86 rubber boot and won't be changing back again I don't think.
So no leather boots for me anymore, lol. That was 18-year old Jeff's decision. ;)
Jeff
