::::EDIT:::
I just realized that this is in the wrong spot, mods plz move to 7mgte technical plz!
Ok guys I'm having an annoying studder at 1500 RPM's. My wideband goes lean, and the car shakes with throttle if I'm keeping her around 1500 rpms.
Mods:
2jzgeT w/ 7m Electronics.
2mm headgasket
SAFC
AFPR
Lex afm
RC Hi Imp injectors with resistor box bypassed
Single turbo kit.
I have a high idle (bov is leaking a bit, doesn't leak as much, but still leaks) around 1000-1300 but usually 1000 after warm up. My tps reading on my safc bounces around .01-.06 i can't adjust the TPS anymore and I've tried two different TPS, and verified the wiring.
The car runs pretty good like I said, it's got a bit of a miss, but that's from the coil packs (original one from 88!) I have a speed sensor code and a IGF code (assuming it's the coils, that and the coils are waaaay out of spec.)
if i'm driving and I try to keep pace at 1500 rpms (say, in a neighborhood) she'll shake and sputter, and sometimes it feels like she'll cut fuel all together (like if I'm at 2-5% throttle), and it's annoying the heck out of me. If I'm at 1400 rpms, or 1600 rpms, she won't do it, just at 1500 rpms. I adjusted the SAFC a bit, and it didn't seem like it got better.
I have noticed, that if the car is FULLY warmed up, she won't do it as often.
I love the car, but working out the kinks are killing me! I also have a slight miss it seems, but I'm still saying it's the coils, and I don't know anyone local I can swap with, but I'm waiting for a good deal for a set of IS coils.
Mods:
2mm headgasket
SAFC
AFPR
Lex afm
Single turbo kit.
