1200 rpm idle, is there any..
mikeoc1
109
Ft Benning
..anything obvious that could be unplugged or failed that would cause my idle to go from a near perfect idle 700rpm consistantly, to starting it today and it idle at a steady smooth 1200rpm. Runs fine, no codes but cant figure what could have happened while it was sitting that would cause it.
swordofdoom
17
Arkansas
I found a bunch of air hoses on mine that were all taped together and cracked. It was idling at that rpm too ever since I got it. Hopefully replacing them will solve the problem.
jetjock
creepy-ass cracka
9,439
Because it's not an idle adjustment. On the GE that screw is used to set idle mixture (on the GTE it has a different purpose) which is why idle speed changes when it's messed with. Not only are you masking the real cause of your problem but you're throwing the EFI system out of calibration. That's why the factory goes through the trouble of precisely setting each screw and then coding it's position onto the housing.
jetjock
creepy-ass cracka
9,439
Idle speed should never be adjusted using mixture. It's set by the amount of metered throttle body bypass air and on this engine that's done by the computer. Even if you set idle speed by mixture the computer will still try to control it. What you end up with is bad mixture and an idle control system that's out of whack.
Look for a two digit number near the screw. When decoded it indicates the distance from the housing to the top of the screw in mm. The easiest way to decode it is to give you examples: if the number is 30 the distance should be 13.0 mm. 26 would be 12.6 mm, etc. That's where it was from the factory. Depending on what's been done to the car it may not be right now but it should get you close.
mikeoc1
109
Ft Benning
bioskyline;1741017 said:
cold start circut not shutting off?
This has been resolved, not sure what it was. Car had a low battery when it happened. After charging the bat all night it was fine. Not sure if that was related, but no problems since.
kwatso23
47
Mid north coast
Just a query on the two digit stamp near the screw. I recently built a new N/A motor and am currently trying to sort out why the car is running so rich.
I've checked near the screw on my AFM and I have no two dogit number?
Anyone got any ideas?
