100ft lbs
Status
Not open for further replies.
JDM 1JZ
I hate Tires
Aug 31, 2005
301
Cherry Hill, New Jersey
using a stocker hg and arp studs, is 100 ft lbs to much for the gasket aslong as oil is used instead of moly lube as per the directions request. i dont know if it will crush the gasket to much or if theres and issues about that, what do you guys tq to?
You should use the ARP spec on the Supra...the friction coefficient of the studs/nuts is dependant on the lube used to get the torque spec. Moly is more slippery, thus the lower torque to get the proper clamping force between the block/head.
dallas
previously 89jdm7m
Oct 23, 2006
VA Beach
um... follow arp head studs... they've been doing their shit for god knows how many years now... those specs they give you are results of extensive tests....
'nuff said... arp know's what they're doing
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
as a side note, does anyone know where ot get soem moly lube? my set from bobiseverywhere came with about half of it used (his studs were used and i etched for used because they have gone throuh heat cycles)
JDM 1JZ
I hate Tires
Aug 31, 2005
301
haha probley, it is just a bunch of useless functions really, i just couldnt really reasist... umm as for the lube theres a couple perfomance shops here in jersey im certain they sell i can find out how much, i know it comes in a little tube, whatever it costs me it will cost you if you want me to find out
89supturbo
186
Delmar, NY
its not the lube used that affects the tourque spec its the metal that the bolt is made out of, bolts are tourqued to 70% of the elastic limit, the bolt is actually stretched to increase the clamping force, with a stonger metal the elastic limit is much higher and therefore to get the same clamping force you need more tourque
dallas
previously 89jdm7m
Oct 23, 2006
VA Beach
JDM 1JZ said:
81 and moly it is, now i cant wait to play with my new snap on t-wrench, she vibrates beeps and all kinds of crazy shit, all digital, cant wait
damn son... you musta dropped 1,000 just on that wrench... either that, or killed a guy for it :biglaugh:
dallas
previously 89jdm7m
Oct 23, 2006
VA Beach
:rofl: do not argue a statement made by jdub :biglaugh:
... chances are, you'll be proven wrong :dunno:
JDM 1JZ
I hate Tires
Aug 31, 2005
301
yeah weres j dub at haha, yeah um that wrench was actually only 400, which is alot i guess but its snap on, life time blahb lahb lah, and i dont pay all at once so its all good
Actually we are kinda talking about the same thing...but, you're mixing apples with oranges ;)
He's talking about the stretch method of determining preload on the fastener...it requires a stretch gauge to be done properly. Stretch is measured in thousands of an inch...I couldn't find the spec, but for most bolts/studs it is somewhere around 0.005".
I was talking about the torque wrench method of installation...perhaps I wasn't clear in my statement above...the lube used determines the friction coefficient that must be overcome for proper torque. From the ARP site:
"1. The friction factor changes from one application to the next. That is, the friction is at its highest value when the fastener is first tightened. Each additional time the fastener is torqued and loosened, this value gets smaller. Eventually the friction levels out and becomes constant for all following repetitions. Therefore, new fasteners should be tightened and loosened through several cycles before applying final torque. The number of times depends on the lubricant. For all situations where ARP lubricants are used, five cycles are required before final torquing.
2. The lubricant used is the main factor in determining friction, and therefore, the torque for a particular installation. Motor oil is a commonly used lubricant because of it’s ready availability. If less friction is desired in order to install the fasteners with less torque, special low friction lubricants are available. With special lubes, the required torque can be reduced as much as 20 to 30 percent. It is important to keep in mind that the reverse is also true. If the torque value has been specified for a particular fastener on the basis of low friction lube, installing the fastener with motor oil will result in insufficient preload; the torque has to be increased to compensate for the extra friction caused by the motor oil."
The material used in the bolts does determine the amount of stretch required to reach the proper clamping force. However, since very few of us own a stretch gauge, the torque wrench method is commonly used. When using this method and using the ARP spec for the lube used, the bolts are torqued to 75% of the rated yield strength of the bolt. Since moly is a low friction lube, you can reduce the stud torque to 81 ft/lbs instead of the 105 ft/lbs for motor oil.
Note: To do this correctly, you should torque through several loosening/tightening cycles. ARP (per above) recommends 5 cycles.
Status
