10 psi on stock 7mgte: goor or bad?
speedfreak
SCruzer
May 16, 2006
109
santa cruz, ca.
im running ten psi on my stock supra 7mgte it seems fine but when i first installed the boost controller it was only boosting about five i thought stock was supposed to b eight am i boosting too much?
MKIIINA
Destroyer of Turbos
Plano, TX
stock is 6.8 psi. 10 psi with no other mods (intake/exhaust) is asking for trouble. you are pushing things too hard with too much restriction on the components. i suggest taking off the boost controller until after you get caught up mod wise.
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
no way, turn the SOB up to 30 pounds!!!! WOO WOO..... just kidding, real bad idea
johnathan1
Supra =
Aug 19, 2005
5,056
Yea, the stock exhaust system is ridiculously restrictive...it will do more harm than good.
If you have a stock exhaust, more boost won't help you make any extra power...it will just generate excess heat, which is already a problem for 7M's.
aye mate
Hiatus over.
Maryland
Yea, something along those lines. Get a bigger exhaust and at least retorque the head before you turn up the boost.
SURUKO
making the supra better..
Jan 8, 2007
610
The tropical island....
It is right to go 10 psi if I have a walbro fuel pump and afpr, 3" inch exhaustand k&n intake filter ,can I go for 15psi?
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
I run 14psi every single day and i drive very hard on the factory fuel setup. Granted my car is in great shape mechanically and my HG is torqued down to 70lbs.
Mods
Intake
3 inch (elbow back)
holes in my accordian hose (boot leg but it gets the job done raises boost cut :icon_bigg )
Shimmed Waste-gate
plaaya69
87T Supra
Nov 18, 2006
947
10
Lake County, IL
Do you have a stock head gasket or a metal headgasket? Also do you have stock headbolts? If so you should get some arp headbolts.
supraman16
SUPRASAVER
Jul 23, 2006
68
Atlanta
I'm running 18 psi with ARP head bolts, metal head gasket, 550cc injectors, Lexus AFM, Apexi Cold air, 3.5" down pipe with 3.5" full exhaust, SAFCII and AFPR. No probs.
shaeff
Kurt is FTMFW x2!!!!
11
Around
^ don't type in all capital letters. it's really annoying, and considered yelling on the internet. i edited your post so that nobody else would jump on you for it.
with that said, are you on the stock turbo? if so, you're asking for trouble. 15+psi on the stock ct-26 is just blowing heat.
-shaeff
bountykilla0118
Jul 16, 2005
1,088
Atlanta GA
-shaeff
and at 14psi? What about the upgraded ct's i have read and heard 17-18psi on the pump gas.... what do you think?
TurboWarrior
Canada
If the car is bone stock its hard to even get high boost anyway. You have to really push it. On the highway you might. 10psi takes a lil while
irocznissan
109
nj
well 10 should be fine not doin destructive damage. but if u go up to 15 u need to retorque the head and get an exhaust. gauges are life savers so invest in them to see what ur car is doin. but wit the stuff u listed u can do 15 but u wont feel any big difference
