10.5" Rears?? How bout 9.5" Fronts?? Advice needed
Supra Sam
33
Sydney
Hi All,
Looking at a set of rims, unfortunately I can't test fit them before I buy them, Just need some feedback from people who either have this setup or have tried it.
Front 18x9.5 +41 offset
Rear 18x10.5 +41 offset
I found a couple of other threads on this topic, but nothing concrete.
http://www.supramania.com/forums/showthread.php?t=10819&highlight=10.5+wheel+offset
I thought I remembered Doctor Jones putting 10" on the front with no issues, but I checked his site and found nothing. Might have been someone else.
All help/feedback appreciated
Sam :)
May 18, 2007
704
Aarhus
I have 10" in front. Only thing is mine have ET14.
This is also 10" in front:
image.asp
I don't know the offset on that one.
So all in all not much help for you there.
I rolled the fronts a little so it doesn't rub there but now and again on a BIG hit it'll run the inner plastic if the wheels aren't straight.
Same rims on the rear but with 285/35's.
Supra Sam
33
Sydney
image.asp
Do you know who's car the second one is?
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Not on the rear. It pretty much depends on the wheel and what offset you have. The mkiv tt rear wheel inside is pretty close to the bottom of the strut.
