10.3@147 22psi..
2jzmk3
Guest
went to the track this weekend with darin and a few other friends.
my best run was 10.3@147 this was on W/G spring so 21-22psi
i didnt have time to mount my real tires so i was on shitty 26x11.5 et streets. so traction for me was really limited, darin has the boost down to 8.8psi off the line and it still spun like crazy.
the car is making some good power if you check the mph, at only 22psi on boost i am trapping 147 with a 1.7 60ft.
with a good 60ft at the same boost i should be able to go 9 @150 i still have alot more boost and spray... second time to the track with the car so i am happy i got to drive it there, make over 8 runs, and drive i back home.
i still have a few other vids to post, so i will have to upload them.
http://www.youtube.com/watch?v=YkBXs75r584
enjoy
new vid added, same boost, same everything, my speed sensor stopped working so i was testing it out to make sure it worked.
next time out, im going 9's for sure... i am turning the boost up and i have my new tires mounted.
http://www.youtube.com/watch?v=laDP166bDnw
What clutch set up are you running and how do you like it?
Roughly how much power are you making at 22psi?
Thanks, and your car sounds awesome..............:bowdown:
2jzmk3
Guest
im running the 6spd w/ tilton triple carbon clutch.. i love it i have tried alot of clutch setups from 5spd to 6spd and this is by far the best.. its making about 720-730@ 22psi
Tein Flex suspension is on the car.
2jzmk3
Guest
yes, my rev limit is set to 8300 right now. it still makes power past that, but thats where its set currently.
we were going to go to tampa, but when we heard that there was a private track rental we decided to go to that.. better track, more runs, less waiting, closer to home, etc..
suspectsupra
208
homeless
damn if only i knew
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Wow, Sean, the car looks, sounds and pulls GREAT. Not to mention its got a TON left in it. Congrats. You guys are doing it big down in FL. Good luck with everything!
TheNewRed
572
WA
Thats a beautiful car sean! What front runners are you using, and do you drive em around on the street?
mako18
64
FL
Badass car!!! What front valance is that?
Also this is off topic but do any of you orlando people happen to know Mike aka 89supraturbo62688. I need to track him down I know for a fact that he knows some of these people on the board. thanks and any info is appreciated please pm me!!
