10.0 Afr
Justin
Speakers?
Spokane, Wa
Is a 10.0 rich enough to cause an rough ride in boost?
When I boost in 1st and 2nd gear I drop down to 10.0 and it is a rough ride (which is why I don't boost often). Not as bad as a miss and my plugs are new and gapped correctly.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
my friends car does the same thing, we went out tuning today, 16psi and 10.3:1 AF and it wanted to break up, but didnt too bad. i shoot for 11-11.5 whenever i tune.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
seeing as 10:1 is the bottom of the scale on most (maybe all?) widebands you could be aproaching 9:1 for all you know. Basically you are off the scale pig rich and yes that can definately cause issues. Before I had Lucy tuned after my rebuild I would hit that far down the scale and it would buck like hitting fuel cut.
Justin
Speakers?
Spokane, Wa
Thanks guys.
Just to clarify, I'm not after a 10.0, that's just what I'm at right now. I have not started my tuning process.
Good idea weezL, You may be correct on that, but at the same time it'll fluctuate a few tenths so I think I'm staying higher on the 10 scale but as you pointed out, no way to know :)
I just wanted to see if that was a possible problem so I didn't try and chase down other shit.
I'll get started tuning as soon as I can find a way to rig my damn Vista lappy to communicate with my maft proness
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
My NTK wil read down to the 8s, or atleast low 9s.
