She's going to the dyno so its time for a guessing game!! :D
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
I called down there today and they are booked COMPLETELY solid all this week because of an EFI Class they hosted this passed weekend. So it looks like next week sometime. :(
CajunKenny
Nov 15, 2007
3,255
Washington
May the Supra-Gods have mercy on me............................
queenskid926
Tires yeling @ every Lite
Jul 27, 2007
1,112
New York City
also resist the urge to go a little bit leaner to get that extra 10-15rwhp, its always that extra 15rwhp ur trying to squeeze out via border-line lean afr or a little bit too much timing that causes it to blow.
Blue87T(Dan)
St. Clair Shores, MI
CajunKenny;1557496 said:
You guys are sooo silly.....
I did get a few runs in; but, after seeing what the wastegate was doing, I called it quits. It just needs adjusting. I adjusted it a little bit tonight; but, she's not quite there. Once wastegate pressure is ~13psi. We're strapping her back down.
Would you mind posting some sheets or numbers from those runs you did get in?
Thanks,
Dan
CajunKenny
Nov 15, 2007
3,255
Washington
SideWinderGX;1562514 said:
I meant 495 tq not 595 :p (Was taking 5 from hp and tq, finger must have slipped).
How'd the numbers come out with the messed up wastegate?
Fixed your guess for you SideWinder... (Mr. Fat Fingers... :biglaugh:)
I don't have sheets; but, at 8 psi the car made 278 hp and at 14 psi it made 298. I knew something was wrong at this point; but, just to confirm it we did a pull at 16 psi and only picked up 3 hp. That's when we stopped.
I will get it to the other dyno by next weekend. Earlier if I can...
