BATTLE VERSION adjustable arms
RPSil13
464
Anaheim, CA
Moy;1561315 said:
how have these held up since first install?
ive had them on my daily for over a year now and they are working great, no noise, no creaks, etc
i will be going back shortly and getting the last arm made (the one w/ the tab for the swaybar), alex told me that he has a design so you can adjust the it w/out removing it
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
there is big reason why mine aren't aumline i hate heim joints on street car they go loose ware out blaa bla blaa ( thus why i hate a1 stuff may be pretty but at lest i don't have to worrier about it )
polly bushing and an adjuster/jam nut for me :)
if it was made of aumline well the thread get pulled wreacked ect
i think most every one can agree with me
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
That would be nice. Are there any plans for having poly bushings as an option instead of heim joints?
Dimman
Back to the Left.
I'm considering making a set of these for my own cars. I'm a machinist and have access to an engineer who is a car guy at work. His recommendations: First was use chrome-moly (4130 or 4140) tubing. However I'm not a welder and asked about aluminum as an alternative. His recommendation was to compare the tensile strengths of the materials and then adjust the diameter (for cross-sectional area) of the aluminum bars to compensate for the lower tensile strength. That and make sure the threads are machined to the appropriate engagement %. So what I got for my Subaru (first car I will be trying these on) is that the stock arms are about 19mm/.750" diameter. Tensile strength of 1025 steel is rated at around 60-103 kpsi, 6061-T6 aluminum is rated at approx. 45 kpsi. So working with 80kspi for the stock arms the aluminum arms must be 1.78 times greater in cross-sectional area. So what I got was at .750" diameter the cross-sectional area is .442 square inches times 80kpsi gives me 35.36. 1.000" diameter the cross-sectional area is .785 square inches times 45kpsi gives me 35.34. Close enough. However he still wouldn't recommend these for racing and chrome-moly is still his first choice. (also use at least 5/8" alloy rod ends/heim joints)
I haven't measured my Supra's links yet so I'm not sure how much bigger the aluminum versions will have to be. Another alternative is using 7075-T6 which has a tensile strength of about 83 kpsi but is significantly more expensive.
The problem I see with these ones being offered is that the diameters of the steel vs aluminum bars looks like they are the same. This would make the aftermarket bars only 56% the strength of the stock bars (assuming they are 6061-T6). Also the diameter of the bar replacing the stamped/welded stock piece (with the holes in it) is quite a bit less, and there is also stiffness to account which I haven't got into yet.
Any thoughts?
