92TealSupra;1141898 said:There is a decent manifold on ebay right now to fit twin turbo on a 7m-gte motor check it out just type Supra manifold and look you'll find it, good luck.
$0.02
Kristian_Wraae;1142044 said:Where is your spirit? Why do we even bother fixing up an old Supra? Because it is different. So why go TT 7M? Because it is different.
Two smal Garrett turbos can be had for very little. Less than a Garrett T4.
figgie;1142003 said:And what about the piping?
The oil lines?
The down pipes, mid pipes?
The intakes?
The PVC?
The compressor outlet to IC routing?
so many things to address besides just the "manifold"!
92TealSupra;1142143 said:Well starting him off is always a good thing. The manifold would be the starting ground. IC piping I am sure he may be able to figure out, intakes are nothing, PVC? You mean "PCV" That would be easily routed, the route would have to be custom fab'd up, but again I am helping him piece it together.
Keros;1142196 said:It's a common misconception that two turbos are better than one.
It will not likely ever be better, just different. Different power band placement and different driving characteristics, but probably not better due to the inefficiency of using two turbines instead of one. Twice the cost, twice the complication, quadrouple the headaches.
I'm a strong advocate that if you really dedicated yourself to doing a true sequential twin turbo 7M and were openly willing to foot the possible 5 figure pricetag, you'd find alot of support here. It'd be one badass car.
If it was just going to be a parrallel twins setup, meh... it's been done, there's no real advantage to it. Think of it this way; you're making 3 cylinders each spool one pint sized turbo instead of 6 cylinders spool one larger turbo. If your goals aren't too lofty, around 500hp per say, it's not hard to do on a good DBB turbo setup ($2500) with a low boost threshold and tolerable lag. Two decent turbos that will spin out 500hp would probably be more than $1250, so just in turbo costs, you're already down money.
Don't get me wrong, I'd still be jelous... but I'll be glad my wallet wasn't the one to take the hit on it. Threads like this are like the 24 hours friends rule: if you see something you want to impulse buy, your friend talks you out of it. If you still want it in 24 hours, go back and buy it. Saves alot of money and alot of remourse.
We're trying to make you understand the insurmountable odds you'll face on the road to a TT 7M, not hating on your decision to do it. That way you don't go in blind and end up stalled on the project or just scrapping it half way though.
IwantMKIII;1142152 said::nono: gl with that
92TealSupra;1142250 said:you've got to be joking rousting two hoses into the turbo inlets?
He most likely will not be able to use a afm, and have to go with a stand alone, which would be heaps easier.
IJ.;1142334 said:My "spirit" would be when I did a Twin Turbo L24 in a 240z way back in the 1980's
There is no real reason to do twins on an I-6 these days with modern Turbo's available.
IJ.;1142369 said:Come cut my lawn Emo Boy![]()
