Engine -Overhaul Data - 1G-GTEU
Engine
Description
Specification
Value
Action
Note
1G-GTEU
Bigend bearing bolt torque
500
kg cm
Torque
1G-GTEU
Bigend bearing oil clearance
0.016 - 0.047
mm
Clearance
1G-GTEU
Block surface distortion
mm
Clearance
1G-GTEU
Camshaft bearing cap
150
kg cm
Torque
1G-GTEU
Camshaft oil seal retainer
N/A
kg cm
Torque
1G-GTEU
Camshaft pulley bolt exhaust
475
kg cm
Torque
1G-GTEU
Camshaft pulley bolt intake
475
kg cm
Torque
1G-GTEU
Clutch pressure plate bolt
N/A
kg cm
Torque
1G-GTEU
Cylinder bore oversize 50
N/A
mm
Measurement
1G-GTEU
Cylinder bore size p 1
75.00 - 75.01
mm
Measurement
No.1 & No.6: 74.99 - 75.
1G-GTEU
Cylinder bore size p 2
75.01 - 75.02
mm
Measurement
No.1 & No.6: 75.00 - 75.
1G-GTEU
Cylinder bore size p 3
75.02 - 75.03
mm
Measurement
No.1 & No.6: 75.01-75.
1G-GTEU
Cylinder head bolt
650
kg cm
Torque
1G-GTEU
Cylinder head distortion
0.20
mm
Clearance
1G-GTEU
Flywheel bolt
N/A
kg cm
Torque
1G-GTEU
Front crankshaft pulley bolt
2200
kg cm
Torque
1G-GTEU
Main bearing bolt torque
600
kg cm
Torque
1G-GTEU
Main bearing oil clearance
0.026 - 0.053
mm
Clearance
1G-GTEU
Piston nil clearance
0,055 - 0.075
mm
Clearance
No.2, No.3, No.4 & No.5
1G-GTEU
Piston oil clearance
0.045 - 0.065
mm
Clearance
No.1 & No.6 cylinder
1G-GTEU
Piston oversize 50
N/A
mm
Measurement
1G-GTEU
Piston ring grove clearance No. 1
0.03 - 0.07
MM
Clearance
1G-GTEU
Piston ring grove clearance No.2
0.02 - 0.06
mm
Clearance
1G-GTEU
Piston ring grove clearance oil
N/A
MM
Clearance
1G-GTEU
Piston size p 1
74.935 - 74.945
MM
Measurement
1G-GTEU
Piston size p 2
74.945 - 74.955
MM
Measurement
1G-GTEU
Piston size p 3
74.955 - 74.965
mm
Measurement
1G-GTEU
Ring end gap number 1
0.25 - 0.46
mm
Clearance
No.1 & No.6: 0.22 - 0.43
1G-GTEU
Ring end gap number 2
0.20 - 0.44
null
Clearance
No.1 & No.6: 0.17 - 0.41
1G-GTEU
Ring end gap oil ring
0.20 - 0.79
mm
Clearance
No.1 & No.6: 0.17 - 0.76
1G-GTEU
Tappet cover bolt
N/A
kg cm
Torque
1G-GTEU
Timing belt idler
370
kg cm
Torque
1G-GTEU
Timing belt tensioner bolt and nut
220
kg cm
Torque
1G-GTEU
Valve clearance exhaust
0.25 +/- 0.05
mm
Clearance
1G-GTEU
Valve clearance inlet
0.20 +/- 0.05
mm
Clearance
1G-GTEU
Valve guide bush oil clearance exhaust
0.030 - 0.063
mm
Clearance
1G-GTEU
Valve guide bush oil clearance inlet
0.025 - 0.058
nun
Clearance
1G-GTEU
Valve length exhaust
93.85 - 94.65
mm
Measurement
1G-GTEU
Valve length inlet
93.80 - 94.60
mm
Measurement
1G-GTEU
Valve spring distortion
2.00
mm
Clearance
1G-GTEU
Valve spring length exhaust
43.85
mm
Measurement
1G-GTEU
valve spring length inlet
43.85
mm
Measurement
1G-GTEU
Valve stem diameter exhaust
5.955 - 5.970
mm
Measurement
1G-GTEU
Valve stem diameter inlet
5.960 - 5.975
mm
Measurement
