1ggte (u) information
Ma70.Ent
1,871
NJ
I was referring to maybe a list of required parts, and maybe some info on if you would need to modify stuff like you would have to on a 1JZ (motor mounts)
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
with mine it was used with na motor mounts na tranny and the usual 1g ecu and dash gauges. i didnt do the install but got it shortly thereafter. theres a guy on sf called project supra he did his all by him self i think.
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
i was comparing the 89 7m ecu vs the 1g and theres actually very little that is actually different, theres only a couple of wires different and of course there being 3 inj signal wires vs two on the 1g
the 1g's are the same as any a70
get same year mounts and engine harness... and plug her up and i think you're good to go :)
you may need to do some wiring at the ignitor coil side of things as thats slightly different to 7m but it shouldn't be too hard ;)
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
OKay, I checked the 1g tach that came in my car but was not working. I got it to work today. It is exactly the same and nothing needed to be changed to work with my 1jz setup.
If you look at the 1jz gauge cluster wiring, it shows the 1g as well.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
I am looking for one also! I think what i will do is take a hi resolution scan of the TRD 10K rpm gauge and print up a new back plate then use it, and tune my standalone ecu to drive the tach so that it matches the RPMs with the display or ecu logging
ekoston69
7
Australia
hey guys just in regards to the 7mgte 430cc injectors into the 1ggte, has anyone done this and do you need resistor pack for them to run properly?
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
i do know that when i had my 1g alot of the info i looked up said that people were using the rx7 turbo injectors . as far as using resistors im not sure.
SupraOfDoom
Starcraft II ^^;;
Milwaukee, WI
I was looking at information about weights of the 1JZ compared to the 1G-GTE on another site, but I'm not sure how legit they are.
Does this sound about right?
1JZ-GTE - 477 lbs
1G-GTE - 385 lbs
I'm also looking for information on the length of the 2 engines if anyone has this info!
saywhat!
Here
Will the JZA70 disc rotor, anchor plate and caliper be a direct bolt on or do I need to fab some thing to make it fit?
