1ggte (u) information
shaeff
Kurt is FTMFW x2!!!!
9
Around
Tthis is a sticky for those who have the 1ggte engine. We can do this several ways:
1) Just make this a gigantic ongoing thread, or
2) Post questions in the regular forums, and once they're answered, place links to them in here, and we'll keep it updated. It's up to you 1g guys. let me know either in here, or via PM, and we'll get this rolling. :)
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
Engine -Overhaul Data - 1G-GTEU
Engine
Description
Specification
Value
Action
Note
1G-GTEU
Bigend bearing bolt torque
500
kg cm
Torque
1G-GTEU
Bigend bearing oil clearance
0.016 - 0.047
mm
Clearance
1G-GTEU
Block surface distortion
mm
Clearance
1G-GTEU
Camshaft bearing cap
150
kg cm
Torque
1G-GTEU
Camshaft oil seal retainer
N/A
kg cm
Torque
1G-GTEU
Camshaft pulley bolt exhaust
475
kg cm
Torque
1G-GTEU
Camshaft pulley bolt intake
475
kg cm
Torque
1G-GTEU
Clutch pressure plate bolt
N/A
kg cm
Torque
1G-GTEU
Cylinder bore oversize 50
N/A
mm
Measurement
1G-GTEU
Cylinder bore size p 1
75.00 - 75.01
mm
Measurement
No.1 & No.6: 74.99 - 75.
1G-GTEU
Cylinder bore size p 2
75.01 - 75.02
mm
Measurement
No.1 & No.6: 75.00 - 75.
1G-GTEU
Cylinder bore size p 3
75.02 - 75.03
mm
Measurement
No.1 & No.6: 75.01-75.
1G-GTEU
Cylinder head bolt
650
kg cm
Torque
1G-GTEU
Cylinder head distortion
0.20
mm
Clearance
1G-GTEU
Flywheel bolt
N/A
kg cm
Torque
1G-GTEU
Front crankshaft pulley bolt
2200
kg cm
Torque
1G-GTEU
Main bearing bolt torque
600
kg cm
Torque
1G-GTEU
Main bearing oil clearance
0.026 - 0.053
mm
Clearance
1G-GTEU
Piston nil clearance
0,055 - 0.075
mm
Clearance
No.2, No.3, No.4 & No.5
1G-GTEU
Piston oil clearance
0.045 - 0.065
mm
Clearance
No.1 & No.6 cylinder
1G-GTEU
Piston oversize 50
N/A
mm
Measurement
1G-GTEU
Piston ring grove clearance No. 1
0.03 - 0.07
MM
Clearance
1G-GTEU
Piston ring grove clearance No.2
0.02 - 0.06
mm
Clearance
1G-GTEU
Piston ring grove clearance oil
N/A
MM
Clearance
1G-GTEU
Piston size p 1
74.935 - 74.945
MM
Measurement
1G-GTEU
Piston size p 2
74.945 - 74.955
MM
Measurement
1G-GTEU
Piston size p 3
74.955 - 74.965
mm
Measurement
1G-GTEU
Ring end gap number 1
0.25 - 0.46
mm
Clearance
No.1 & No.6: 0.22 - 0.43
1G-GTEU
Ring end gap number 2
0.20 - 0.44
null
Clearance
No.1 & No.6: 0.17 - 0.41
1G-GTEU
Ring end gap oil ring
0.20 - 0.79
mm
Clearance
No.1 & No.6: 0.17 - 0.76
1G-GTEU
Tappet cover bolt
N/A
kg cm
Torque
1G-GTEU
Timing belt idler
370
kg cm
Torque
1G-GTEU
Timing belt tensioner bolt and nut
220
kg cm
Torque
1G-GTEU
Valve clearance exhaust
0.25 +/- 0.05
mm
Clearance
1G-GTEU
Valve clearance inlet
0.20 +/- 0.05
mm
Clearance
1G-GTEU
Valve guide bush oil clearance exhaust
0.030 - 0.063
mm
Clearance
1G-GTEU
Valve guide bush oil clearance inlet
0.025 - 0.058
nun
Clearance
1G-GTEU
Valve length exhaust
93.85 - 94.65
mm
Measurement
1G-GTEU
Valve length inlet
93.80 - 94.60
mm
Measurement
1G-GTEU
Valve spring distortion
2.00
mm
Clearance
1G-GTEU
Valve spring length exhaust
43.85
mm
Measurement
1G-GTEU
valve spring length inlet
43.85
mm
Measurement
1G-GTEU
Valve stem diameter exhaust
5.955 - 5.970
mm
Measurement
1G-GTEU
Valve stem diameter inlet
5.960 - 5.975
mm
Measurement
i'm new to this site. i just recently had a 91 1ggte put in my 89 ma70. a few problems already. one-no tach, two-can't find a down pipe or really i just need the flange, three-the car doesn't like to idle, four-this is more of a question than a problem for now but, i went to atmospheric dump (bov) do you think that might have some to do with the idle problem? the only place i have found that can find anything for this motor is www.toyospares.com they are in australia i sent them my wire loom and they got me some other needed parts very helpful. anyways if anyone has any ideas for me i open for any suggestions i only recently got in to the whole supra thing. i drive and 03 evo and that has been my main focus so i needless to say i am ignorant about the supra
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
their is a goliath dp im not sure who makes it but its out there. as far as a bov these cars didn't come with them so no they dont like them but if you do use one then yes it will make the car idle weird and run really rich from my experience. you can get a bosch bov and it will run ok. why dont you have a tach? do you mean not in the gauge cluster or what exactly? have you checked your timing? yours is a 3rd gen so it should be running 10-11 psi stock. www.importbitz.com has a single turbo mani with a 40mm ext. wastegate for 550 and you can find other parts for them over in aussie. and japan. in japan they made a full stroker kit at one time you can search yahoo japan auctions they have them sometimes
i will have to check the spelling on that site. thanks for the info. maybe i will sell the ssq HKS bov. and get an internal or half and half. i have a tach but maybe during the swap that wire didn't get hooked up or something but now that i have the diagram i can look for it and do it myself. do you know what size injectors are stock on the 91 1ggte i swwaped them with the 7mgte n/a that are 430cc i think so i hope i didn't screw myself.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
if im not mistaken they are 330cc stock i have a set of na injectors do they just swap right in? i know for a fact that 13bt injectors will work they have to be rewired but they are 550cc. how well does yours run with the 430cc inj.
also you should join www.supraforums.com.au they have quite a bit of knowledge on the 1g check it out.
hmm good question i don't know it was the N/A so i hope i didn't down grade. it runs fine, right now i have to adjust my piping because i keep blowing boots off. but ya i dind't have to mod anything to put those injectors in, one of them is leaking right now because the o ring i think so i have to fix that next, it is still very much in the works i still have no down pipe (no exhaust at all right now) i need to find a down pipe or just the flange so that i can at least make my own. because it would be nice to get a exhaust on there and get it inspected.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
on supraforums.com.au they would know where to get the dp and who makes them. i dont have an exhaust either haha but i have a guy who will inspect mine anyways hehe. what all after market upgrades do you have? do you know what type of plug wires i need ?
