Your MaftPro settings
Archon
67
Russia
www.200mph.ru
Hello!
Maybe you guys just post your personal settings?
I think it can be use full.
Please describe mods of your car.
And complete this with YOUR settings:
Menus My Settings
Config
Vehicle Select 0
# of Cyl 6
Displ 3.00
Airfl Mode Speed Density
MAP Source GM 3 Bar
DENS Srce Use MAP
Baro Mode Sealevel
F Out Mode Supra MKIII
V Out 1 mde Use Setpoint
V Out2 Mde Use Setpoint
AFR Source 5V AEM Guage
F In Mode Supra MKIII
Aux 1 Mode Aux Trig Off
Setup
Mainscale -10.00
V Out1 Set 2.500
V Out2 Set 3.600
Afterstart 0.0
Lo Load Pt 36.4
Mid Load Pt 100.1
Hi Load Pt 143.0
Freq Out Max 0
Timing Mon Base 0.00
Timing Monitor Corr 1.27
AFR Tracking Delay 0.0
FE Smoothing 00
Use VE Table #1
Spk Base 0.0
Boost Control
TPS Spool 2.000
RPM Spool 2400
TPS Start 2.800
PSI Start 13.0
DC% Start 50.00
PSI Set 16.0
PSI Aux 14.0
Gain 10.0
DC % Start Aux 10.0
Max RPM 0
AFR Tracking
Min TPS 2.440
Min RPM 3488
Min MAP 148.2
Lean Lim% 5.0
Rich Lim% 25.0
Gain 4.0
AFR2000R 11.5
AFR3000R 11.5
AFR4000R 11.5
AFR5000R 11.5
AFR6000R 11.5
AFR7000R 11.5
AFR8000R 11.5
Aux % 0.0
Air Temp
-40.00 0.0%
13.00 0.0%
41.00 0.0%
62.00 0.0%
82.00 0.0%
103.00 0.0%
129.00 0.0%
173.00 0.0%
212.00 0.0%
Aux Triggered
All 0.0%
Tuning
RPM High Mid Low
400 -10.0 -10.0 -10.0
800 -10.0 -10.0 -10.0
1200 -10.0 -10.0 -10.0
1600 -8.0 -10.0 -10.0
2200 -8.0 -8.0 -10.0
2800 -5.0 -6.0 -8.0
3400 0.0 -6.0 -5.0
4000 0.0 -5.0 -5.0
4600 0.0 0.0 0.0
5200 0.0 0.0 0.0
5800 0.0 0.0 0.0
6400 0.0 0.0 0.0
7000 0.0 0.0 0.0
7600 0.0 0.0 0.0
Tune Response
TPS Enrich 0.00
TPS Delay 0.8
TPS Size 7
TPS MAP Max 104.0
MAP Enrich 0.2
Boost Enrich 0.4
MAP TPS Min 0.5
MAP RPM Min 640.00
MAF Limit TPS Threshold 0.00
MAF Limit 0.00
MAF Limit/KRPM 0.00
Timing Monitor
Spark WOT Spark Aux
2000 0.0 0.0
2500 0.0 0.0
3000 0.0 0.0
3500 0.0 0.0
4000 0.0 0.0
4500 0.0 0.0
5000 0.0 0.0
5500 0.0 0.0
6000 0.0 0.0
6500 0.0 0.0
7000 0.0 0.0
7500 0.0 0.0
8000 0.0 0.0
Failure14
276
Ohio
Archon;1338883 said:
Hello!
Menus My Settings
Config
Vehicle Select 0
# of Cyl 6
Displ 3.00
MAP Source GM 3 Bar
DENS Srce Use MAP
Baro Mode Sealevel
Setup
Mainscale -10.00
V Out1 Set 2.500
V Out2 Set 3.600
Afterstart 0.0
Lo Load Pt 36.4
Mid Load Pt 100.1
Hi Load Pt 143.0
Freq Out Max 0
FE Smoothing 00
Use VE Table #1
Spk Base 0.0
Boost Control
TPS Spool 2.000
RPM Spool 2400
TPS Start 2.800
PSI Start 13.0
DC% Start 50.00
PSI Set 16.0
PSI Aux 14.0
Gain 10.0
DC % Start Aux 10.0
Max RPM 0
AFR Tracking
Min TPS 2.440
Min RPM 3488
Min MAP 148.2
Lean Lim% 5.0
Rich Lim% 25.0
Gain 4.0
AFR2000R 11.5
AFR3000R 11.5
AFR4000R 11.5
AFR5000R 11.5
AFR6000R 11.5
AFR7000R 11.5
AFR8000R 11.5
Aux % 0.0
Air Temp
-40.00 0.0%
13.00 0.0%
41.00 0.0%
62.00 0.0%
82.00 0.0%
103.00 0.0%
129.00 0.0%
173.00 0.0%
212.00 0.0%
Aux Triggered
All 0.0%
Tuning
RPM High Mid Low
2800 -5.0 -6.0 -8.0
3400 0.0 -6.0 -5.0
4000 0.0 -5.0 -5.0
4600 0.0 0.0 0.0
5200 0.0 0.0 0.0
5800 0.0 0.0 0.0
6400 0.0 0.0 0.0
7000 0.0 0.0 0.0
7600 0.0 0.0 0.0
Tune Response
TPS Enrich 0.00
TPS Delay 0.8
TPS Size 7
TPS MAP Max 104.0
MAP Enrich 0.2
Boost Enrich 0.4
MAP TPS Min 0.5
MAP RPM Min 640.00
MAF Limit 0.00
MAF Limit/KRPM 0.00
Timing Monitor
Spark WOT Spark Aux
2000 0.0 0.0
2500 0.0 0.0
3000 0.0 0.0
3500 0.0 0.0
4000 0.0 0.0
4500 0.0 0.0
5000 0.0 0.0
5500 0.0 0.0
6000 0.0 0.0
6500 0.0 0.0
7000 0.0 0.0
7500 0.0 0.0
8000 0.0 0.0
Your better off doing test and fail runs yourself,
Someone else's settings that are perfect for there car
doesnt mean there gonna be perfect for your car.
And nonetheless its about "you" and how "you" like
the car to run.
No offense but this is one of the most fucked up questions
ive read on here within the time ive been on this forum...
Its kinda like me asking some other guy "Hey what are all the
aftermarket parts you got in your car and where did you get them from? i
want my car to be just like yours."
I mean yes we are all here to help each other but to an extent its still
a competition whether its track times or looks.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
asking for boost control and PTT is not a dumb thing to ask, but asking for everyones specific tune wont help anyone. i know when i first started with the maftpro, i had no idea how i should set up the boost control. someone who was running a similar turbo and the same desired boost as i was looking to run told me his settings and i worked from there to get it where i wanted it.
maybe if the OP had a specific question about the tune he has posted, and perhaps attached a log... then some of us would help
-pete
