WTF wheres my connector??
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
Soo.. im lost here i have a 1988 Toyota Supra with a 7mgte/R154 im trying to put the pieces together after the previous owner suck major balls...
OKay NOw..i have the regular clutch fan right... Next to that i have 2 small radiator Fans..from what i learned the connectors are behind the Battery or atleast the wires/connector are in the general area but i see 2 wires coming out of the wiring harness for 1 connector
im pretty sure im missing another 2 wires to make the second connector for the fan
noel
Uchiha Member
May 5, 2008
512
yhatzee89;1952202 said:
Maybe he replaced the -89 single with the 89+ double fans. Has the front end ever been damaged...?
NOt that i can see im guessing he had the fans on a switch or something hence why the wires were cut ...i just wanna make sure it doesnt overheat with just one 1 fan
noel
Uchiha Member
May 5, 2008
512
Jeff Lange;1952736 said:
I would wire it up to use both. There's a reason Toyota added another fan, it can use it, haha.
Jeff
i would love to use both but that means i would have to rig the seond fan with a switch since the wiring harness doesnt support 2 fans
noel
Uchiha Member
May 5, 2008
512
jetjock;1952652 said:
Or just use both. The small fan(s) are actually there for the AC system.
how can i use both? if theres no Connector on the harness for the second fan i have to rig up a switch for incabin use and become a 1 fan human thermostat lol...
mkiiichip
1,434
WI
The likeliness of hackery is much greater, trying to get the dual fans to work. I still say just get the steup its already designed for.
noel;1954086 said:
so pretty much what your saying is just add the other fans 2 wires into the existing connctor ...I didn't think the curcuit could handle another fan
You'd think wrong...
