WTF Temperature guage moving Help Please
LamaRossa
One and Only LamaRossa
Apr 6, 2005
131
ct
Yes i've spent an hour reading all the posts
CAr
89 SUpra turbo 216k 100k in a rebuild motor MHG ARP the whole 9 yard
Diagnose
water pump works because the upper rad hose has pressure
fan clutch works fine
Problem
68 deg tonite driving on freeway notice temp usually sits at 4 oclock but tonite its about 2 oclock running a bit hot
my temperature guage has never moved
turn on the heat it went down
pulled ova no overflow or bubbles on the overflow bottle which is a good thing
noticed that one of my wire on the thermostat housing was broken off , the bottom sensor with one wire blue with white strip
The senosor is on bottom of the thermostat hub where the rad hose goes in to not the housing on the block
anyone knows what the hell this bottom sensor does. ????
i respliced it but would this cuase my car to run hot and move the temp guage???????
also notice tonite after driving the car for 35 min the top rad hose still hard meaning i think my thermostat is stuck close
but did not overhead driving home maybe because i drilled holes in the stock thermostat so that it still would flow a lil when it is stuck
anyone got a clue????? comments are always welcome
Ciao
Lamarossa
Eric_Odie
163
Fremont, Ca.
for me, my gauge started to move and die out when that wire was loose and coming off the blue thing. what i did was put that wire back on the blue thing and taped it with electrical tape so that it doesn't come off again, and after that my gauge worked fine and still works fine...
DrakeMK3
"The Duck"
Knoxville, TN
If it's the sensor with the round blue connector, that is the connector for the electric a/c fans. I don't know how that would affect your temperature needle unless you were running a/c at the time your temperature rose.
SupraMario
I think it was the google
7
The Farm
if you thermostat is stuck open you should be over cooling, 99% of all the thermostats now have a fail save where it opens when it fails, I had same well similar problem, my gauge read almost hot then after driving for like 2 days that way, it died. i replaced the theremostat and it works just fine now.
14u2c
RAFO
four-one-three
I was having the same problem on monday, so I flushed the radiator and refilled with new fluid. Than jacked the car up and burped it. No more moving needle. Good luck Rafael.
LamaRossa
Apr 6, 2005
131
ct
Thank you friends
just got up im heading to toyota for a new thermostat and o ring also planning on flushing my coolant system today
hopefully all is well
thanx again for the responses i got mad work to do
Ciao
Lamarossa
LamaRossa
Apr 6, 2005
131
ct
Yup new coolant and new Thermostat from toyoa def did the trick
Drove for an hour in the hot no problem
thanx again
Ciao
Lamarossa
