7mgte running speed density and map3 bar, wideband is a Innovate lc1, the wideband is reading AFR's at 14.9 the maftpro says they are at 22.0 tried different settings also reseted the maftpro and re-entered all the values. Also getting code 22, 24, 35, 51 from the ECU, all this started happening after my battery died, I recharged it and still same thing, tried resetting the ECU still nothing.
