After replacing my shattered oil pump drive gear, timing belt, and decided to replace my plugs since I've had them sitting here for 10 months, I have noticed my valves clicking at idle only.
What I am wondering is if they gave me the wrong plugs, I have a GE and the plugs I got I had to re-gap them quite a bit. I don't remember the plug numbers they were NGK's. If they gave me the turbo plugs, which I think the gap was set at, would that cause the clicking that I am hearing?
Oil pressure is 70 cold start and 20 at idle, 45-50 at 3k after warm up.
I double checked the cam marks and TDC also the timing is at 15 deg. AFR at idle is 13.5 cold and 14.5 warm.
Thanks
AJ
Thanks
AJ
