Would this t3 Garrett be a good fit for a 7m?
dylansword
114
boise id
There is a t3 garret turbo on Craigslist in me area for $325 and I am wondering if it would be a good fit for a 7m?
Here is the website.
http://www.atpturbo.com/mm5/merchan...tp&Product_Code=TBN-TBO-013&Category_Code=TBN
These are the specs the guy put on the ad:
COMPRESSOR - .42 A/R, 46.5mm Inducer, 60mm Exducer, 60 Trim. Hose style inlets/outlets - 60mm Inlet, 50mm Outlet
CHRA - Oil cooled T3/T4 oil inlet/outlet flanges, 270* Journal Bearing.
TURBINE - A/R - .48, Inducer - 58mm, Exducer - 48mm, Trim - 70. Inlet - T3 flange, 45mm x 57mm, Outlet - 3 bolt, 55mm
Please only helpful input. Thanks
radiod
1,342
Abbotsford, BC
Right in the description on the link you put up it says that it's good for 250hp. Seeing as stock CT is good for more than that I'd say you're taking a step backwards.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,242
Atlanta
250hp would be a good bump for a normally aspirated 1.4 - 2.0 4 cylinder, and i think thats the kind of engine that this t3 is probably geared towards.
radiod
1,342
Abbotsford, BC
Yeah, would be a good candidate for a Honda B series, maybe a Toyota 1ZZ/2ZZ or 4A-GE. There would be lots of potential customers for a small turbo.
Numba1Stuna
361
Nampa, ID
Hey Dylan, if you are wanting an upgrade, check out Alberts turbo rebuild thread. He can upgrade the ct26 several ways. That's what I'm considering doing.
Sent from my LG-P999 using Tapatalk 2
Suprapowaz!(2)
2,870
San Antonio, Tx.
