Issue: car makes a noise, best way to describe it is sort of a wobble. I know it is not engine related as if I pull the clutch and let the car to to idle, the noise is still present. My car has no rear interior in it so it makes it fairly easy to hear the noise coming from the rear. Only thing that is making me second guess myself that it's in the rear is that if going in a straight line the noise is prevalent, if I turn the wheel very slightly to the right the noise goes away, bring the wheel back and the noise comes back. I can also hear a slight whine from the rear end when I slightly get into the gas after decell but it goes away after applying any more throttle, but I hear this normal.
Things recently done to the car:
Installed eibachs, they are saggy and really bad, coilovers coming soon
The noise became prevalent after washing the car (doubt it has much to with it)
Rack has been leaking so topped it off
Things I've checked:
Lug nuts (stupid but simple)
Tire pressures, all checked fine
Wheel bearings, but was a fairly quick check
Things I'm going to check:
Wheel bearings jack up and do correctly
Ball joints
Tie rods
Maybe bushings (have a brand new set of energy bushings to put in)
Backlash in the rear end
Service the rear end
Anything else I should be aware of or check? I also sometimes hear a large clunk when taking off from first when first moving I'm assuming its rear end
Ball joints
Tie rods
