Seems as you had a bad expirience with one. The odds of a Wix filter failing are extremely low. The fact remains that, as far as filtration and value, the Wix outperforms most filters on the market.
			Kckazdude;1094149 said:Seems as you had a bad expirience with one. The odds of a Wix filter failing are extremely low. The fact remains that, as far as filtration and value, the Wix outperforms most filters on the market.
QWIKSTRIKE;1094157 said:They may filter well but they are cheap pieces o shit IMHO. You get what you pay for for sure. They may work under low pressure under 40 psi but high pressure causes them to break. I used it 2x. I Burst fram filters 3 times before I figured that they are just not good at High ressure. Mobile one, and K&N held up under pressure. Gold going to K&N.
Kckazdude;1094253 said:I have heard the buzz that states the 'R' series withstand more pressure but have never been able to confirm it. The only difference I know of is the flow rating and ADBV placement on the 'R' series.
Big Wang Bandit;1094254 said:I have people coming in with 600-700 HP hotrod/drag cars, and have never had a burst filter. You either got a bad one, or your engine is seriously fubar.
Part 51348 is for the 7MGE and GTE. The other part number listed is a nominally smaller filter, why use a smaller filter?
I pulled up a 51515 and the oil seal rind is a milimeter wider than a 51348(7M filter) So itll work as long as you have the space.
51348=stock 7M filter
51515=ford V8 filter(HUGE)
My computer calls for all Lexus V8 filters to be 51348, but I know toyota OEM sell them larger.
jetjock;1094505 said:I won't get into this other than to say it's amazing how some people still possess the ignorant belief that excessive oil pressure, at any time, is a necessary or good thing.
