With Maft Pro, can ovoid any rich condition under boost, because air leaks?
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
I have A/R rich problem under boost, I try to find any air leak with out luck!, now I’m very desperate because I spend $$$ with some new modification and until now I can test my last set up. :cry:
Engines rebuild
Q45 TB and 3” piping
Turbo garret GT35R
6 puck clutch disk
My doubt is: If I install the maf pro kit, and I have any air leak will not create a rich condition under boost?
My goals 500 Hps
Engine set up:
lex AFM + 550cc + walbro 12v mod
Apexi SAFM II
FPR
Boost set at 18psi
Water injection
Note: And sorry for my grammar :biglaugh:
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Mostly correct. If you install the MAFT Pro system, and the MAP setup for it, then it simply runs off the pressure in the intake manifold and the temperature of the incoming air.
However, it should be noted that attempting to get to 500+ hp with a boost leak of any type is going to be tough.
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
WoW I'll buy it! :biglaugh:
here is very hard to find some one that can help me, or tune my car :cry:.
So Where I can buy it? and what parts do I need?
I have a AEM Wide Band meter and True boost controller, can I used wi the Maft pro?
